Results 1 to 10 of 10
Thread: Auto transmission leak
    Opeler bazz518 is on a distinguished road
    Dec 2007
    Delaware
    9
    i got a 1972 opel gt. the transmission has a leak in it. i replaced the pan gasket and filter. It looks like the leak is coming from the passanger side by the drop down cable. any ideas where or what could be leaking? i thought i would check on here before i took it to a trans shop.
    Opel Adventure # 77 NC kevinfier kevinfier's Avatar
    Jul 2002
    West Coast of Illinois
    213
    My best guess would be the dip stick tube o-ring.
    Kevin
    2,675
    Quote Originally Posted by kevinfier View Post
    Kevin
    Or possibly the o-ring on the kick down cable. I've also seen a crack in the kick down cable cover be the source for a leak. You might check the vacuum modulator as well. There isn't much else to check.
    Hoosier Opeler rrossjr is on a distinguished road rrossjr's Avatar
    Mar 2004
    indiana
    558
    Kevin
    That's where mine was leaking. An easy fix (see file posted by Anon-D)
    Also, be careful not to overfill. See FSM (or search here)for the proper procedure for checking the ATF level.
    Cheers,
    Ron in Indy
    1,795
    After the leak is fixed, check the breather/vent to make sure its clear.
    Small insects love to build there nests in tight places.
    Aug 2004
    Planet Earth
    538
    It's not easy. You have to be prepared to have to lower both the engine and transmission, just to get adequate access to the dipstick tube seal.
    Adding silicone above the o-ring also requires that the tube be supported in the correct position and dry, for 24 hours for the sealer to fully cure.
    Dec 2007
    Delaware
    9
    thanks for everyones help. another question where can i get the drop down cable O ring?
    Member ghcoe is on a distinguished road ghcoe's Avatar
    Feb 2009
    SW Idaho
    308
    And the dip stick tube O-ring?
    Dec 2007
    Delaware
    9
    yes and the dip stick O- ring. i think its one or the other.
