Hi.
Does anyone know whats the camshaft profile of a original 2.4cih engine?
Thanks in advance,
Pedro.
This and that
Thanks.
How do this cam works on a 2.0 head? Can i take any power from the cam on a 2.0 head?
I would become friends with a cam grinder and I mean close friends.
And have a custom cam ground just for your combo.
Most oem's and also the aftermarket "fudge" there numbers.
You'll need some very detailed info beyond the obvious..weight,trans,rearend gear....
Port volume..
Valve c/l to throttle plate distance..
cross section area..
exhaust primary size and length
and on and on
This and that
once again, thanks for your reply.
Im in the process of building a 2.0 head with a 1.9 block of my Manta A.
Im going to go with a big valve head 40/45 and a camshaft 282º from Dbilas and porting, polish and working the head so i can get a better flow, knowing that the intake is the one to take a better care, since the exhaust is preety much ok, right?
I allready had read a lot of info but unfortunatly i still have some questions...
With this 2.0 big valve head, can i use my stock 1.9 pistons?
Do i have enough clearence from valve to piston?
The head is stock, never been milled.
I have seen some topics here but i remember that i saw some info like tutorial on building a 2.0 street head and a 2.0 racing head, but unfortunatly i dont find that anywere...
What do you think about this recipe? Will it work good?
Opel Engine Performance Modifications - The Classic Opel Forums
This is the first place to look.
This and that
This and that
Something to consider is that the 2.0 head has different airflow characteristics than a 1.9 head. You will need to re-work the inlet and exhaust ports in *equal* amounts when modifying a 2.0 head, since it is the most balanced 'as cast' CIH head.
The 1.9 head has very good exhaust ports, but poor inlet ports, so it must be modified accordingly.
I have never done this for the 2.0 heads, only for the 1.9 heads. Similar, but certainly not the same!
With a standard camshaft, no problem. I have no idea if there will be interference with the Dbilas camshaft however, sorry!Bob, am i gonna have problems with the 40/45 valves with the stock pistons of the 1.9 block?
Perhaps, I know on the RROC site he has some photos and guides for preparing the 2.0 heads.
I think that with 45 mm inlet valves, it will be very close. I say this because the valve-reliefs in the piston tops are not correctly located, the inlet valves will strike off-center to the reliefs if there is interference. Exhaust should have no problem however.what do you think about this cam from dbilas:
Lift
at TDC
2,3
I will talk with Hiro. I´m going to buy some stuff from him and i´m going to ask about those pics. I remember that it was a great tutorial about building the 2.0 head street and race one´s.
This is my problem. At this moment i don´t want to mess around in the block, and pistons, but i guess i have to...![]()
what can i expect in HP with this changes?
I allready have 2 webers dcoe, supersprint header(independent for each cilinder)and 50mm exhaust tube.
I still have the original muffler but I allready have read that changing the back muffler is also a good help, can you confirm?
The safe valve clearance is .080 on the intake and .100 on the exhaust?
Can anyone confirm please?
