Results 1 to 15 of 15
Thread: Flushing Differential
    1971 GT CDN OpelNut CDN OpelNut's Avatar
    Feb 2003
    Trail, British Columbia
    532
    I got the rear end out of the car. I thought it might be worthwhile to flush out the old gear oil from the diff and replace. Can anyone recommend a method for completely flushing and cleaning the gears prior to refilling. I'm willing to remove the cover to get it done. Should I bother or just drain and refill?
    Member ddoyle
    oakland,or
    242
    If you are changing all the seals, you may want to consider switching to a synthetic gear oil. If not, and you haven't had a bearing or gears go bad I would pull the cover, clean what I could reach and re-fill.
    DAN
    4,161
    By all means, take the time to flush the differential. I use Varsol in a spray bottle, spray it liberally inside and down the axle shafts, and then drain it out. I have also done the same on transmissions before I rebuilt them. It makes it MUCH tidier to work on without the hypoid oil sticking to everything. And flushing the diff might remove some offending piece of shrapnel that would otherwise prematurely terminate it's life.
    corning ny 14830
    2,174
    Can the axel half shafts stay in to flush it out? what is "varsol"
    Opeler Lindsay
    San Diego, CA
    524
    Varsol and Mineral Spirits
    http://www.recochem.com/english/prod...ts/varsol.html
    Varsol* is great for automotive cleaning to remove oil and grease, and for thinning oil based paints, varnishes and polyurethanes.
    * Varsol is a registered trademark of Imperial Oil Limited. Recochem Inc. is a licensee.
    Seems to be Canadian product... ?
    http://www.recochem.com/cdnav/cdprohsfaq.htm
    Q: What is the difference between Mineral Spirits and Paint Thinner? What other names is it known by?
    A: Mineral Spirits has fewer aromatic solvents while other similar products - Paint Thinner, Varsol® - contain higher concentrations. All are petroleum distillates.
    Q: What is the difference between Varsol® and regular Paint Thinner?
    A: Regular Paint Thinner is a "generic" brand of thinner while Varsol® carries a guarantee of purity. As a result, Paint Thinner is usually less expensive than Varsol® but can be used for many of the same applications.
    Member guyopel is on a distinguished road guyopel's Avatar
    Feb 2003
    Duluth,Ga.
    661
    I would recommend that you stay with standard diff. fluid , pull the cover clean & inspect , also clean the vent . Then drive
    corning ny 14830
    2,174
    the diferential is completely out of the car and there were some fine metal flakes in it so I will be flushing it one way or another. Then would paint thinner be fine? deisel fuel?
    4,161
    I didn't realize that Varsol was a Canadian thing. Imperial Oil is "Esso" here, which you might know as Exxon. But in any event, any decent non-volatile de-greasing solvent such as Gunk or even paint thinner (sub-terps, aka turpentine) should be fine .
    corning ny 14830
    2,174
    Would I have to gut the differential first to do this? (bad idea) or just try to get as most thinner out as humanly possible?
    2,001
    Jordan,
    I would not disassemble the rear if you don't have to, flush it the best you can, then if you are concerned about residual thinner, fill drain and refill, that should take care of any pockets of solvent, matter of fact, better to fill, drive for a couple of miles, then drain and refill.
    Opeler Lindsay
    San Diego, CA
    524
    Differential fluid drain plug (bolt) ...
    Removal of bottom, center bolt on differential cover allows lubricant to drain.
    After cleaning differential "insides" with appropriate solvent of choice, leave rear cover off for several hours (or overnight) to allow cleaning vapors to evaporate.
    Quote Originally Posted by Lindsay View Post
    Hmmm - what is the easiest way to FILL said GT differential once drained and cleaned?? I don't think there's a fill plug - or did I miss one on my 73?
    Thanks!
    Paul S.
    Flagstaff AZ
    Feb 2003
    532
    Quote Originally Posted by paul.catherine View Post
    Thanks!
    Paul S.
    Flagstaff AZ
    I'd say you missed it. There is a fill plug that normally takes a hex driver. If my memory is correct, it's on the upper right of the cover.
    2.4 "Legere" Stroker - Weber DCOE45 - Getrag - Compufire - S10 Clutch
    Flamable!
    I would not put anything more flammable than Diesel or perhaps Kero into a diff to clean it.
    Best to just take the back cover off and use a diesel soaked brush to sweep the debris out of the bottom of the housing. Any greater 'flushing' is just as likely to distribute debris around and into the bearings - making things worse!
    If there are lots of chips and flakes in there, the diff is 'on the way out' any way.
    Years ago my father and the mechanics he worked with used to use kerosene
    for all their cleaning - used to be much cheaper than anything else.
    I've used in many times and seems to work fine.
    roger
