Results 1 to 4 of 4
Thread: FI Pump Question
    SW Missouri
    1,358
    FI Question
    I have a question for those who have done the FI conversion. What are the specs for the fuel pump needed? flow rate and pressure? Plus what is a good, but low cost fuel pump to use for same? I did several searches but didnt find the answer. Thanks.
    FI Fuel Pressure
    My 1975 to 81 Opel B Series manual says:
    Regulated pressure ....... 42 +- 3 lbs/sq in (3 +- 0.2 bar)
    Output ....... 1.5 to 2.0 litres/min
    That is the regulated pressure in the fuel rail so I can only guess that the actual pump would be capable of a higher pressure and it is controlled by the regulator in the feed back line.
    You will probably find that the GM "J" Car series have a suitable in-line pump as they use Bosch based injection systems too.
    Unless the ones over there have pumps in the tank.....
    Member ddoyle
    oakland,or
    242
    Almost all FI GM's use a pump in the fuel tank(I can't think of one that does not). Many VWs and Audis use a frame mounted pump. Also several late 80's Fords.
    DTD
    5,072
    the "j" from europe has an inline mounted next to the tank
