Could be a vacuum leak. Spray some carb cleaner around the base of the carb. If the idle smooths out, you found a leak.Originally Posted by Scott McDonald
The Pinto DFEV's have the primary barrel opposite the DGEV's and it may cause a couple of cylinders to burn lean. I'd switch to the DGEV. (plus the throttle linkage will be straight)
money spent now is almost always money saved later
