From what I know my harness has two platic white square connectors and yours should also if it's a 75 harness, if not it's a later European wiring harness I think??? As they went to one rely in the later model I beleive. David 27, otto and Kwilford are good ones to reply!
And thought to add check the forums under factory fuel injection, do your own home work when possible as this thread could be gone from the main page in two days.
Bummer I know but if you read enough you could be just as confused as you started out to be, or you maybe could find your answer sooner!
Regards,
Rick
I am trying to wire the side of the dual relay that goes to the fuel bump, ignition switch, starter, coil,ground, and the battery. The problem I am having is identifying which terminals on the relay goes to what components. I have a Bosch book that gives relay number coding, but I have not been able to make the relay work properly. Could someone with a '75 tell me what color wires go to each numbered connection on the dual relay?
