Results 1 to 10 of 10
Thread: Radiator Options?
    Radiator Options?
    Ok, since a few of the opel parts on a gt have gm parts numbers, i was wondering if anyone knew the gm part number for that model radiator. If not, i'll either get an old one re-cored or find a good radiator that i like (inlet and outlet location/size and overall dimensions) and cut the rubber mounting brackets off of the header panel and whatever else necessry to mount it.
    "The past is past, the future is now"
    Your best bet is to take it to your local radiator shop and have them order you a 3 core. There is a company in Ohio, I think, that has them. I don't have my notes in front of me, but I think the total for the core was $215,and the side panels that include the rubber, are kept from your old one. If you go this route, your new radiator will sit 1/4 to 1/2 inch higher than the old one. You will have to modify the bottom rubber mount. Not hard to do. Here's the post, but I didn't see the fabraction Otto posted. http://www.opelgt.com/forums/showthread.php?t=3333
    I'll see if I can get a picture of mine from underneath today. Hth, Jarrell
    2,622
    A couple of us in the middle TN area took ours to a radiator shop and upgraded to the 3 row and I don't recall any mods having to be made. And the price here was under $200 it may well have gone up since I last had one done.
    I guess it depends on the area and the shop Harold. Jarrell
    Member azopelnut azopelnut's Avatar
    Yuma Arizona
    695
    radiator
    Would a aluminum radiator out perform a 3 core?
    I have also heard that a a larger tube two core will out perform a three core
    Paul "azopelnut" Heebink
    1956 Studebaker Power Hawk 259 V8
    1970 GT 12A-Rotary 5-speed
    1972 GT 2.0, 5-speed
    1973 (2) GTs, both 1.9 4-speed
    1973 Ascona 4-door 1.9 4-speed A/C
    1974 Manta, 1.9 Auto A/C
    1975 Sportwagon 1.9 FI 4-speed A/C
    1975 Fiat X19
    2,622
    Common sense should tell you that the rows to the rear would be less efficient at lowering the temperature as increasingly warmer air is passing over each new row.
    I've carried GT radiators to a radiator shop and the proprietor mentioned that the ones with more fins were a better design.
    There are probably examples that would back up what you say but I think the bottom line is the amount of surface area exposed to the coolest possible flow of air.
    An Aluminum radiator would be lighter and better. A friend of mine is drag racing a "GT" with a big block and was told when he first bought the car that he would only be able to make a few runs at a time because of the cooling system. He contacted a specialty company explained what he had. He sunk $500+ in a radiator and solved the previous owners problem.
    self admitted opel addict free4u2nv free4u2nv's Avatar
    Apr 2002
    mt.vernon,il.
    227
    Are there any radiators out there that will interchange with the 1.9 L Opel GT's (1970)? Looking for a new radiator and just not prepared to pay the price offered by OGTS right now.....Save theirs 4 wishful thinking! Am interested if anyone has a real good one (function / appearance) 4 sale. Email me....
    free4u2nv
    My Opel doesn't just turn heads...it breaks necks!!
    searching...
    There are quite a few threads around here somewhere the search should have turned up.
    One option for the GT might be the rad from a '93-ish civic. Aftermarket ones, like this:
    http://cgi.ebay.com/ebaymotors/92-95...49414843QQrdZ1
    are pretty reasonable and should fit if you can make bracketry. Not sure if the $30 new single pass aluminum ones would be up to the task, but they say radiator size is most closely related to HP and if so the Honda and Opel are pretty darn close...
    If you already have a GT radiator and it's suspect, just go to your local rad shop and have them put in a new 3 row core. Very seldom do the upper and lower tanks go bad, and it's just a matter of taking off the tanks and soldering in the new core.
    Opeler caramiciu is on a distinguished road
    Nov 2005
    Dracut,MA
    177
    radiator brackets
    I am looking for a radiator but also for the brackets that would need to be made.
    Any help would be appreciated.
    I have access to a couple of Gt parts cars.Let me know if you need something and I'll check it out
