Results 1 to 20 of 37
Thread: Weber 32/36
    Member ZmokE is on a distinguished road ZmokE's Avatar
    Apr 2004
    Zeeland (Netherlands)
    258
    Weber 32/36
    Hello all.
    I have plans to change the Solex carb for the Weber 32/36.
    But when i look around here and there i see there are different types of Webers.
    For example, Weber 32/36 DGEV, Weber 32/36 DFAV, Weber 32/36 DFEV.
    So now i'm a bit confused.
    Is there any difference between those Weber carbs, and what kind of type i need for my GT?
    Thanks in advance.
    Rini.
    7,560
    Quote Originally Posted by ZmokE
    Hello all.
    Thanks in advance.
    Rini.
    You should try to use a DG-series carburetor. The DGV has a manual choke (cable), the DGAV has a water choke, and the DGEV has an electric choke. Other than jetting, that is the only real difference between those models.
    PS, this question should be posted in the downdraft carburetor forums!
    Hell hath no fury like a moderator scorned....
    4,466
    Weber 32/36 DGxV vs. DFxV Types
    Hello all.
    Thanks in advance.
    Rini.
    The 32/36 DG and DF types have opposite primary/secondary throttle locations. When mounted on the CIH intake manifold and viewed from front, DG types have primary on left while DFs have primary on right. DG types are the ones commonly used on Opel CIH engines.
    Yesterday, I was going through the K & N catalog, on line, looking for a suitable air filter for my new hood/engine swap and saw a very neat filter housing for the Weber carbs, it even has two remote air inlet openings on it so cold air can be routed to the housing from outside the engine compartment. All that being said, I don't know if it will fit within the confines of the hood bump on a GT. But it may be worth a look. Check them out at: http://www.knfilters.com/Racing/plenum.htm
    Moderator's Note: Added complete link
    Opelitis since 1984 GoinManta is on a distinguished road GoinManta's Avatar
    Midlothian, VA
    2,233
    Well if the one you got in the picture is the one you are receiveing you did good. Its already setup with the Opel linkage and air cleaner adaptor. So it should be properly jetted as well. Should just bolt on.
    Remember to replace the carb mounting studs, the solex ones are too long for the Weber to go on easily.
    Charles
    CURRENT
    '06 Pontiac GTO
    '71 Opel Kadett 4 Door 36D (w/ Opel Parts & Service 2.0L)
    '74 Opel Manta (Bens Manta)
    '74 Opel Manta (w/ LK5 transplant)
    Past
    '73 Opel Manta (Blue Max)
    '75 Opel Manta (Yellow)
    '85 Bitter SC
    '73 Opel Commodore B GS
    '73 Opel GT (w/ Vinyl Roof)
    At least 16 or So Parts Opels
    Good Carb...
    Looks like that carburettor has been set up for an Opel as it already has the ball on the accellerator linkage and the adaptor on top for connecting the standard air cleaner. Someone has even set the electric choke and idle screw then put a dab of paint on the adjusting screws to make sure they don't get moved before being tried on a new motor - a good buy!
    Who ever set it up is obviously very confident that it is set correctly.
    Midlothian, VA
    2,233
    Just get the seal at the base of the carb set and it will run 10x better than with the solex, 25x if you were having problems with the Solex in the first place
    Make sure to get the base gaskets to install it to the manifold. With a vacuum tight seal at the base you will have no problems with the Weber.
    Also check and make sure you dont have any vacuum leaks at the intake manifold gasket either. Many a carb install has driven a mechanic nuts thinking they had a problematic carb, when it was a vaccum leak where teh intake and head meet that caused the problems.
    Charles
    CURRENT
    '06 Pontiac GTO
    Past
    '85 Bitter SC
    Apr 2004
    258
    Thx Charles....i just read an article. It says that using Ether is an option to check for vacuumleaks.
    I shure will check for that..
    Opeler dmillett is on a distinguished road
    Dec 2004
    N.S. Canada
    40
    From the picture that ZmokE sent on 01-17-2005 of the carb., could someone please the me what the purpose on the large headed slotted screw has that is about an inch below the breather? My car will only idle with this screw backed out about 1/8th of a turn.
    Thanks Dwight
    Split thread
    Dwight - that large "screw" you mentioned on the carb is a plug in the end of one of the ports that connect from the carb base to somewhere inside and not an adjustment on any sort - If the air leak you are creating by unscrewing it make the carb run better then there is something suspect with the air/fuel ratio adjustment of your carb.........
    Valve Seals
    Smoke on start up is usually due to worn valve guides and/or old valve stem seals. See the post below for how to replace the seals without dismantling the motor ....
    Also: The "Tasman Sea" between Australia and New Zealand bears his name - no wonder you have not met him as he was sailing around out here at the end of the 17th Century and is a bit dead now ........
    Dec 2004
    N.S. Canada
    40
    Thanks Jim for the reply. With this screw tight, the car will idle if the Idle Speed Screw is turned in 3 1/2 turns and the Idle Mixture Screw backed out 4 turns. ( From what I have read, this means Lean) With this "plug" screwed out 1/8 th of a turn, both Mixture and Speed screws are at 2 turns. Either way I set them up there sceems to be not difference in the cars preformance. Starts good cold, hot, and no hesitation as far as throttle response.
    ZmokE, I am sorry for butting in on your post!!
    Dwight
    No Fixed Abode ...
    Huh...there are some messages gone here????
    Here is the link - the Thread moved!
    http://opelgt.com/forums/showthread....ht=Valve+Seals
    Apr 2004
    258
    Almost...it's this one http://opelgt.com/forums/showthread.php?t=7353
    Too bad that there is not a confirmation that a thread is moved...
    4,156
    Sorry about that, I added the note in the other thread but not this one. Too many threads, not enough typing speed
    In the future, please try to keep threads "on-topic". If you have another question, please do a search to see if a previous thread has answered it, and if a thread comes close, please add to the existing thread rather than starting a new one.
    Thanks from the OGT.com Moderating team.
    4,466
    Assumptions
    Quote Originally Posted by GoinManta
    Charles
    I definitely wouldn't be so quick to make this assumption, Charles.
    Up to a few years ago when we began actively discussing 32/36 "Opel-specific" tuning within the group here, ~95% of these were just "out of the box" installations! I'd say that's much more than likely the case here too.
    Apr 2004
    258
    No hard feelings Kwilford
    You're right if you say that thread was going off-topic...sometimes it just happens talkin about such subjects.
    And the search function i allready used a lot. As you can see i'm a member since april 2004, and i only have 39 posts. Thanks to the search function who gave a lot of answers.
    But sometimes when you hit the search you get a lot of threads with that keyword. Or it's to complicate to understand for me as a dutchman. Starting a new topic with hopefully a bit easy to understand reply's is then sometimes an option for me.
    Okay...back on topic now
    Apr 2004
    258
    A question...
    There are two small pipes sealed with tape at the carb (see attachement).
    Nr. 1 is for the fuel...i'm pretty shure about that. But what should be connected to Nr.2??
    Ascona-B 2.0E , Ascona-B 1.9, Kadett City 1.6, Kadett City 1.2, Corsa-A 1.2, Corsa-A 1.2, Corsa-A 1.4, Vectra-C 1.6, Astra-A 1.4, Agila (ahum ), Corsa-C 1.4, GT 1.9
    Dutch GT Forum
    No.2 is connected to vacuum, prefferably dist vacuum cannister.
    Apr 2004
    258
    I don't understand it...
    The distributor is allready connected to the intake's vacuum. Is it enough to close the port on the carb...or should it be connected it to something else? I don't see what more should need vacuum beside the brakebooster, the distributor and the valvecover...
    In another thread they spoke about distributors vacuum en vacuum retard...i guess thats the same (my english isn't thát good).
    Another question...i'm waiting for the gasket/spacer...shoudl i use some gasket sealer on it..or is this not necessary?
    Dutch GT Forum
