Rally Bob's recommendation is to angle mill the head .080" on the spark plug side, zero or minimal on the manifold side. The quench area is not affected, only the volume of the chamber, and the timing of the camshaft. To affect the quench area you mill the block to give a maximum of .005" of piston sticking up above the deck. This is to increase CR, but I know the reason you are asking. This might work, it's worth a try. Yes you must spot face the bolt holes. No big deal. Be sure to grind some more room around the chain as mentioned before, you will appreciate this later, believe me!
The dimension of the head, from the deck to the valve cover, is unpublished and we need to keep it that way, OK? It comes up every time we discuss this. This is not just me asking, it was asked of me by several of the best known Opel racers. You know, the famous ones, er, the ones you see on TV sometimes.
I hope this will fix your head. If not, the bigger gasket will, but then we'll have to talk you into going to the bigger bore to match! And the 2.2 stroke... oh and longer stronger rods... and the light flywheel... where does it stop?
