Results 1 to 17 of 17
Thread: Weber 32/36 Tuning
    Swansea, MA
    5,289
    Weber 32/36 Tuning
    New thread for use as a future article.........
    Post any tips regarding the Weber conversion carb that worked for you. Float settings, mixture adjustment procedure and baseline jet sizes or any tricks.
    The out of the box Weber is not set up properly for the 1.9. Tell us how you got yours running properly. If you have not rejetted your Weber, you are missing out on a lot!!
    My '69 GT has a 38 DGAS powering a bored out 1.9 with Jahns high compression pistons and a .432"/224° cam with a Sprint mainfold going through a Lenk resonator . I could not believe the difference in performance after RallyBob worked his magic with the jetting!
    Member Stressed Stressed's Avatar
    Johnson City, TN
    97
    Who's rally Bob? I deffinately need help with my 32/36
    4,160
    OK, Gary, what magic did Bob do to your carb? Jet sizes, emulsion tubes, all the good stuff.
    And "Stressed", where have you BEEN the past month since you joined? RallyBob, aka Bob Legere, is the resident expert, especially on things related to performance. Take the time, go to the "Members" section, look up RallyBob, and read his posts. I think this shortcut will do all that for you:
    http://www.opelgt.com/forums/search....der=descending
    And make a BIG pot of coffee, since you will be a while. Bob has posted 629 times, and started 28 of those. So he spends most of his spare moments answering questions from the unwashed masses.
    Enjoy!
    Swansea, MA
    5,289
    Sprinkled a little pixie dust on it, he did..... Actually I was testing an 'article' feature that will place posts in the center section and condense replys under it and that's where my test post came from. Got sidetracked by the NFL game and forgot to remove it.
    I am gathering info and will be putting together an article on Weber tuning.
    Moderator jimsky jimsky's Avatar
    East Northport, NY
    244
    Just wondering how the progress of the Weber 32/36 tuning article is going.
    Jimsky
    '73 GT
    Johnson City, TN
    97
    Where I've been
    I love this message board. Unfortunately, I spend most of my time these days working, and when I’m not working, I’m working on my 70 GT. I re-bought it two years ago. To make a long story short it was the exactly same car I bough when I was seventeen, sold at eighteen, and found again 13 years later and eight-hundred miles away. I’ve got the car running, but just to run the mix screw is out 5 or 6 turns, and idle is in about 5 turns. I hope to post pictures soon. Maybe I’ll go take them now. Yahhh…. Be back soon.
    Johnson City, TN
    97
    The pictures are posted. How long does it normally take to get the approved where others can view them?
    I don't expect you know what an Opel GT is, but I need some parts.
    Swansea, MA
    5,289
    I get an email when photos are uploaded. I've been working on my new Opel this afternoon. All your photos are approved.
    Re: your idle adjustment, check for vacuum leaks around the carb base.
    1,795
    WOW
    Are there any updates on this old subject?
    I linked off of paint codes to find this thread.
    IMOA dump the weber and install a Holley Oh.. look out ..I'm moving around from all the flack
    This and that
    Swansea, MA
    5,289
    Quote Originally Posted by kwilford View Post
    ...And make a BIG pot of coffee, since you will be a while. Bob has posted 629 times, and started 28 of those. So he spends most of his spare moments answering questions from the unwashed masses.
    Quote Originally Posted by wrench459 View Post
    WOW
    Its there any updates on this old subject?
    Man is that an old thread!
    This was a test thread for one of the many "article" add-on programs that did not last.
    Be careful with the Holley as the primary is reversed (inboard) which causes cylinders one and four to run lean.
    This Space for Rent
    I had a Holley on for the last few thousand miles. Mine was installed backward so primary and secondary were same as a weber, this puts the linkage for throttle toward the front of the car so you'll need to change to a cable and ditch the whole Opel linkage. Anyway. Since the Holley is a mirror of the Weber, it seems to work about the same. Was fine on my car but who can leave well enough alone?
    1,795
    Gary
    The holley I'm thinking of is not progressive in the least bit.
    Then theres the motorcraft carbs with annular discharge boosters.
    Hope you can make it to the Ga. meet.
    This and that
    Search "All these jets"
    WOW
    See title to search . . . "All these jets . . ."
    Opelitis since 1984 GoinManta is on a distinguished road GoinManta's Avatar
    Midlothian, VA
    2,233
    There is also the :
    http://www.opelgt.com/forums/afterma...er-thread.html
    thread.. between the two I think they about cover most everything..
    CURRENT
    '06 Pontiac GTO
    '71 Opel Kadett 4 Door 36D (w/ Opel Parts & Service 2.0L)
    '74 Opel Manta (Bens Manta)
    '74 Opel Manta (w/ LK5 transplant)
    Past
    '73 Opel Manta (Blue Max)
    '75 Opel Manta (Yellow)
    '85 Bitter SC
    '73 Opel Commodore B GS
    '73 Opel GT (w/ Vinyl Roof)
    At least 16 or So Parts Opels
    Aug 2004
    Planet Earth
    538
    Read them, but do so carefully
    Although there are some good ideas, based from actual experience, the thread links cited above, also contain conflicting and potentially misleading information.
    (1) Some advocate changing to F66 emulsion tubes on the 32/26 DGV series, (which possibly is a misread of the recommended change for the 38DGAS. "Rally Bob" contradicted this suggestion).
    (2) Claims the emulsion tubes on a 32/36 "DGxV" differ from those on a 38DGAS, (which are in fact contradicted by Weber's manual itself, which lists same part number for these tubes for both applications).
    Reference for (2):
    http://www.opelgt.com/forums/afterma...e-jetting.html
    Posts #8 & #9, dated 12/16/03:
    (3) "The mixture screw seems to have little effect on the idle quality other than the fact that when it is all of the way in, the idle speeds up a bit."
    The above symptom is also noted, more commonly, when there is a vacuum leak. But only one post (Rally Bob's), on a linked thread, referenced a need to check for that, rather than the suggestion to consider changing jets.
    Reference for (3):
    Post #14, date 6/20/05, quote from "Travis"
    1,795
    Quote Originally Posted by Anonymous D View Post
    "Travis"
    One simple check for this symptom is to look into the primary and see if fuel is flowing from the booster.If so your running off of the transfer slots instead of the idle circuit.
    This and that
    1,795
    Would the Opel Gods spread some info on these's jewels. From what I gather
    they have a direct influence on air fuel ratio.
