You should be able to drill it and easy-out it, but I would have this BIG question.
Torque wrench? If not then you obviously were putting to much into the tightening of the bolts, so I would question the integrity of the rest of the bolts.
Replace them ALL and use a torque wrench when you do!
Of course, that was a great selling point to my wife.
The release bearing, pressure plate, and clutch plate were all mounted on the input shaft of the new transmission. the transmission was then bolted up to the block. (5 speeds have the bell housing integrated with the transmission.)
