The T-5 is a stronger transmission than the Opel 4 speed I have one in my GT and it is about 160hp. No you cannot use your bellhousing without making an adaptor as the bolt pattern is different. The stick comes out in the right spot if you use the S-10 version and you will have to buy an after-market shifter(mine is a B&M). You need to use the S-10 clutch which requires you to machine down the flywheel step flat and lay off the S-10 bolt pattern and drill and tap new mounting holes. The bell housing to use,if you can find one, is a GAS Chevette 5 speed or Pontiac T1000. The bolt holes and dowel pin holes fit the Opel block. Due to the differance in the block height you do have to thread the two top holes in the bellhousing and fabricate two Z brackets to pick up the top bolt holes on the Opel block, modify the transmisson mount cross member (re-drill it) to take the S-10 transmission mount and you will need to make a new driveshaft, using an automatic transmission front yoke. Not a small task,but doable, or you can spent $1000 for the pieces and put in the Gertrag 240 and someone else has done the work for you, and you still have to address the clutch.
but it doesn't have the Opel 2.4L in it it has a Isuzu moter in it.
Why manufacturers do this? You got me.
