+ Reply to Thread
Results 1 to 12 of 12
Thread: Is this a stuck float
    Member azopelnut azopelnut's Avatar
    Apr 2003
    Yuma Arizona
    695
    A friend has a Ascona with a Solex that starts right up, idles beautifully for 5-10 seconds and then start dumping fuel. He wants to keep the Solex. Any suggestions on a fix for this???
    Paul "azopelnut" Heebink
    1970 GT 12A-Rotary 5-speed
    1972 GT 2.0, 5-speed
    1974 Manta, 1.9 Auto A/C
    1975 Fiat X19
  2. #2
    Southern Red Neck BQS4 will become famous soon enough BQS4 will become famous soon enough BQS4's Avatar
    Snellville, GA
    6,174
    What do you mean by "dumping fuel?"
  3. #3
    opel free after 26 years baz is on a distinguished road baz's Avatar
    Jun 2002
    sunderland england
    5,075
    paul when you say it "dumps fuel" do you mean it has gas coming out of the venturi so much that it floods ? if so then yes it sounds like the needle valve in the float chamber is sticking open or the float is holed,flooded and sunk leaving the valve open all the time
    B.O.O.B. founding member
  4. #4
    Apr 2003
    Yuma Arizona
    695
    the main delivery tube (maybe 1/8" wide) leading into the mid point of the two barrell pours fuel into the carb
    1975 Fiat X19
  5. #5
    Snellville, GA
    6,174
    sounds like your needle& seat is stuck open. There are rebuild kits out there on Ebay, but, I think Duane Foley has a stock of them.
  6. #6
    Member timemachine is on a distinguished road timemachine's Avatar
    Jan 2006
    Swarthmore, PA
    834
    This can also happen to Solexes due to heat expansion. If the fuel dump happens when the engine is turned off warm, make sure the top plate gasket is okay and the screws are pulled down tight. On warm cars, heat off the manifold can cause expansion that pulls cooler air right into the float chamber and pressurizes the fuel right down the chute minutes after the engine is turned off. You also sometimes see a surging/stalling effect with hot Solexes that is mistaken for vapor lock, (which is a separate and real problem). Same answer for this, tighten the screws and snug the carb to the manifold, but don't get carried away with the latter or it will warp.
    '74 Manta ("Sig")
    '75 Sportwagon (project)
    '72 GT (whenever I get to it)
    Sold or wrecked:
    '72 Manta Rallye
    '73 Manta
    '74 Luxus
  7. #7
    long time Opeler deaner is on a distinguished road deaner's Avatar
    May 2006
    Fallbrook, Calif.
    297
    Quote Originally Posted by timemachine
    A sign of this is, an improper adjusted fuel bowl vent to the charcoal canister. During acceleration the bowl is vented from with in the Carburetor. At part throttle and idle, the bowl is vented to the canister, This should vent fumes and heat out of the bowl area and prevent purging into the venturies. The setting is more critical than you would think.
  8. #8
    Apr 2003
    Yuma Arizona
    695
    Quote Originally Posted by BQS4
    OK
    I took the top of the carb off and the needle valve was clean but the float was filled with gas so I took a good float off another solex and now the car starts beautifully, idles for about 3 seconds and dies. If I pump the gas pedal it will stay running but barely.....any ideas???
    1975 Fiat X19
  9. #9
    Apr 2003
    Yuma Arizona
    695
    BTW
    I also took the gas line off the carb to see what the flow of fuel was like from the pump and it half filled a smaller peanut butter jar in about 30 seconds.
    1975 Fiat X19
  10. #10
    Snellville, GA
    6,174
    Quote Originally Posted by azopelnut
    OK
    Paul;
    Still sounds like the carb needs a good internal cleaning.
  11. #11
    Site Admin Gary will become famous soon enough Gary's Avatar
    Swansea, MA
    5,289
    Blog Entries
    The Solex in my '72 wagon was "dumping fuel" in a similar way. It cleared up when I took the Idle air valve out and cleaned it. It is right above the air mix screw. It has a hex shape with a screwdriver slot in it and a ball in the center of the screwdriver slot. (great description, eh)
    This Space for Rent
  12. #12
    Jun 2002
    sunderland england
    5,075
    Quote Originally Posted by Gary
    clear and concise and all in highly technical terms gary
+ Reply to Thread
