Unanswered: Solex Carb Problems
By chugging, do you mean that it floods with fuel? Flooding is when the carb pours fuel down the throats uncontrollably, and overloads the engine. If this is the case, the most probable cause is a stuck inlet valve. Remove the air-horn, and you will find it right behind the inlet pipe, at the underside of the air-horn. Remove it with a 15mm socket (if I remember correctly) and work it a bit (it only has a small moving rod) while spraying with carb cleaner from the inlet side... Most of the times this solves it...
To remove the air-horn, you have to disconnect the choke element complete with the coolant pipes(or just the cable if it is electric), and disconnect the fast idling adjusting rod (the threaded rod under the choke, that the choke lever is held on it by 2 nuts). HTH
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by gr_diver; 07-08-2007 at 09:09 AM. |
101st Airborne Vet V.N.
Real Name: Thomas Johnson
GT Crazy,
Everyone on this site will tell you one thing ..... put the Solex to sleep and buy a weber carb. Opel GT Source --- Welcome 32/36 with a electric choke
Thomas Last edited by MICAH1; 07-08-2007 at 07:16 AM. |
I agree with Otto! Not everybody will...
At least not before giving the Solex a chance to prove itself. Even if that means it proves itself bad... But don't consider a $200+ Weber yet, when a 3$ valve could be the problem...
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by gr_diver; 07-08-2007 at 12:10 PM. |
Absolutes.....
Okay guys..... lets just say that ALMOST everyony on this site MIGHT tell you to purchase a weber over the time and effort of bringing the solex back/near orginal performance levels.
The data that I have gotten from the internet, this site, and import car folks back in early 70's when I replaced my solex on my first GT said get a weber you will be pleased. They were right.... I have never gone back. But hey, I will back off and say to GT DRIVER, go with your solex as long as you can.............. and then STEP UP!!! my two cents.
Thomas Last edited by MICAH1; 07-08-2007 at 02:09 PM. |
Get the Weber.
The best Solex repair guy/tuner I know is Bill Daley. He can make them run like a good TAG watch. I used to ship him Solex carbs left and right. For every 10 or so carbs, maybe 2-3 were 'good ones'. The carbs warp in multiple places, and once they warp, they are junk. No rebuild kits will bring them back to life at that point, they are beyond repairing correctly. However, every once in a while there's a 'good' Solex that shows up (I've only had one original Solex that did this personally) that actually performs correctly. The only other Solex I've owned that worked perfectly was an NOS Solex I had years ago...wish I had kept it. Otto has one that works very well on his Kadett, which is probably why he is emphatic about you keeping yours (we all love you Otto, but Solex did not earn their reputation by chance! ).That said, it's genuinely easier to keep and maintain a Weber than a Solex. It is far more tuneable in terms of parts availability and general knowhow, and you'll get a boost in power to boot. The frustration levels are dramatically reduced when dealing with a Weber too. Bob |
gone Opel GT crazy!
i have a solex on my 69 GT,right now it's doing fine....hope it stays that way
Rex {Elda} "code green"1969 Opel GT 4 speed,Weber carb,Pertronix electronic ignition. 1972 parts car auto-RIP 1972 parts car -Rip {saphire}-1993 yellow nissan pick up 5 speed! 1993 red nissan pickup automadic (unamed for now) {Alexia}-1989 chevy camero {Elliott}-1978 Pontiac Firebird -1989 Ford probe(unamed for now) 17 years old -6 vehicles... and still moveing on ![]() WATCH OUT,I'M A OLD CAR FANATIC!!! ![]() Future wanna be concept and custom car designer/builder. |
About the specific problem you mentioned (when opening the throttle, the engine wants to die for a few seconds and then picks up). This sounds much like a faulty accelerator pump. With the air-cleaner removed and the engine not running see down the primary throat while manually operating the throttle linkage. Does the little brass tube inject fuel in the carb's primary throat? It should be a powerful column of fuel, solid and not aerated, which should be aimed between the throttle valve and the venturi wall towards the secondary barrel. If it does not inject fuel, the diaphragm is most likely torn. If it injects fuel, then check the aiming and correct if needed GENTLY with a pair of needle nose pliers (removing the air-horn will make adjustment MUCH easier).
About the low mileage now, what numbers do you get? Low mileage can be caused by several things, and also, possibly a combination of things. Is your engine in tune? That is: 1) valves adjusted, 2) correct dwell setting of the breaker-points (50+-3 degrees), 3) base timing correctly set and advance mechanisms working correctly(both mechanical and vacuum canister(s) on the distributor), 5) distributor rotor and cap in good condition, 4) clean spark plugs and good spark cables If these are verified good, your brakes are not dragging and your clutch isn't slipping, then you can move to the carb for low mileage problems... Check that your jetting is correct for your carburetor. In the downloads section there is a scanned version of the Factory Service Manual (FSM) available for downloading, in it you can find the correct size of jets that should be in your carburetor, and also the correct procedure to make all idle adjustments. The last (idle adjustments) is pretty important, because most of the driving we actually do is on the progression circuit (part of the idle circuit) and less on the main jet, which is most effective above 3000rpms.
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by tekenaar; 07-08-2007 at 03:55 PM. Reason: nose pliers? ;-) |
No Access
In a small nutshell. Do the prophelactic trick on the vacuum secondary unit and replace your spacer for the intake valve with the same thickness and do the surfaces like you would an oil pump cover and use a good rebuild kit and your back in business. On this one I'm on Otto's side. Give it a chance or spend the 300 plus for a weber. Worst case is it cost you 25 bucks and you got to tinker with one.
#12 (permalink) | |
This car only had 26,800 original miles on it and is probably the best documented Kadett in existence, I mean, the original owner kept everything relating to ownership and maintenance of that car! Who else do you know who not only saves all annual registration renewal cards, but also removes and saves the annual license plate stickers! . . . and you thought I was anal! But, back to carbs. When I got the car back to Texas and because everything else was original, I decided to go back to stock when I saw that the Solex still had its original metal carb ID tag! Going through the box full of paperwork I got with the car, I even discovered the original receipt for the Weber replacement carb . . . ring a bell, Bob?! ![]() I thought it somewhat strange that the Solex was replaced without ever having been opened . . . almost always those carb ID tags get "lost" when they're first opened. This Solex is a vacuum secondary type and I quickly discovered the reason for its replacement . . . the most common vacuum Solex failure and which makes this carb completely untuneable, a ruptured vacuum diaphragm. Had no trouble finding a replacement, since almost everyone thinks they're boat-anchors anyway and will gladly give you anything "Solex" just to be rid of it. I must say that this carb performs flawlessly in my only "A/T" Opel . . . end of story.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-08-2007 at 05:28 PM. |
#13 (permalink) | |
But if you want to drive it regularly, I'd go with the Weber. My 'good' Solex in my 1974 Manta worked flawlessly when I got the car. In fact it would spin the 165/R13 radials with a little bit of brake-torquing (automatic trans). But, the day it 'popped' and stalled on me as I was trying to cross a busy intersection was the day I replaced it with a Weber...the Solex nearly cost me my life! Wish I had kept that NOS mechanical secondary Solex though, that thing ran like a bear on my '70 Kadett Rallye. Bob |
Real Name: Jim
![]() Provided Answers: 7
This is an interesting thread, I'd start with tightening the obvious things down and then doing a rebuild if that doesn't work.
I've been thinking of replacing my original Solex on a 34K car since I got it simply because of the CFM numbers that Webers produce versus the Solex 32 DIDTA. I rebuilt a 32/36 and have it on standby for that. I'm also slowly building a new motor that will call for more air but I'm guessing Bob will tell you the rest of the plumbing has to be ready for that for different carbs to make sense. But the three Mantas I owned 20-30 years ago all did well on the original Solex carb, as Otto attests. The worst condition was when the throats actually iced up in cold weather (Chicago) or slightly less cold high altitudes (Colorado). I've also met German Opelers who warn me not to go the Weber route and swear by the Solex. My current Solex works works well and is not warped as far as I can tell, but the stacked manifold setup does cause it to boil over a bit in hot weather after you park it. It doesn't seem to be warping, but internal heat and pressure that causes fuel dump. It wants to flood - a bit - until you're back on the road and everything cools down and then you're fine again. A better fan setup might be the more obvious solution. There was a 1974 Opel service advisory for just this condition I could post if anyone is interested. If I could only find the replacement jets the advisory calls for... Unlike Bob's example, my vacuum secondary is a little frustrating since it doesn't want to trip in the driveway but it seems to work on the road. Otto, I don't doubt you for a second. Bob, you are just six away........ Jim
'74 Manta ("Sig") '75 Sportwagon (project) '72 GT (whenever I get to it) Sold or wrecked: '72 Manta Rallye '73 Manta '74 Luxus Last edited by timemachine; 07-09-2007 at 03:59 AM. |
To make the vacuum secondary kick in in the driveway, for testing that the diaphragm is in good condition, I always do the following.
From the engine bay, with the air-cleaner removed for clearance, I manually open the throttle to the point that the engine revs slightly above 3000rpms (which is the low end of the vacuum activation range). I keep the throttle there for a couple of seconds, then suddenly open it almost WOT and bring it back to approximately where it was. The sudden vacuum that will be created in the primary when bringing the throttle back, together with the throttle being open enough to allow secondary's linkage movement, will make the diaphragm activate briefly. And if the diaphragm is in good condition, you will see it's level slightly opening the secondary valve...
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by gr_diver; 07-09-2007 at 10:02 AM. |
#16 (permalink) | |
'74 Service Advisory
I don't know much about carbs, but I only have experience with the stock Solex carbs, the double barrel types [used on the high compression engines] are somewhat trickier than the single barrel [used on the low compression engines], and we [my brother & I] would change the double barrel for a single barrel Solex carb, doesn't make that much difference to us
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 07-09-2007 at 08:30 PM. Reason: then - time (dan, toenmalig); than - comparative (dan, vergelijking) |
#19 (permalink) | |
All US CIH engines came with either a mechanical- (progressive) or vacuum- (load/RPM dependent) secondary two-barrel Solex . . . period. One barrel Solexes of various sizes and numbers were strictly used on the 1.1 OHV from 1966-on and at the same time that electrical systems were changed from 6V to 12V. All the 6V Opel models sold here from 1958-62 (Rekord PII, 1.5/1.7 OHV) and from 1964-65 (Kadett, 1.0 OHV) used a single one-barrel Carter carb . . .
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-09-2007 at 09:15 PM. |
#20 (permalink) |
Real Name: Jim
Could be that 2 fast is looking at things backwards and sees the "double barrel" Solex as the twin-carb 1.1 setup and the single as the single 2-barrel didta on the 1.9s.
I am looking for that service advisory, I have a few stacks lying around. It's possible that remember it from one of Mach One Tom's collection, he has the best set I know of. I'm pretty sure it was a part number bulletin that did not specify diameters. Probably 1/3 of all Opel service advisories dealt with the Solex. There are too many to attach here but one interesting bulletin corrected the specs in the 1974 factory service manual. I am trying to upload it but my scan distorts the page badly so far. Jim
'74 Manta ("Sig") '75 Sportwagon (project) '72 GT (whenever I get to it) Sold or wrecked: '72 Manta Rallye '73 Manta '74 Luxus Last edited by timemachine; 07-10-2007 at 01:57 AM. |
#21 (permalink) |
one bbl
I do have a 1-barrel intake manifold for the CIH motors, pretty much just has a smaller plenum and the 1.1's Solexes bolt right on. I ran it with a Holley 1-barrel for a long time, actually worked fairly well, and had a cool glass fuel bowl as well.
A good running Solex can and will make for a good running car. We have a lot of folks here who dislike them, but there are millions of VW's and other cars that run them exclusively and have excellent service histories. A pair of 30PICT-2's on a VW 1600 is my induction of choice every time. Solex carbs are a lot like Quadrajets in a lot of ways. Both are excellent pieces of hardware, lots of adjustability, tuned for a good compromise between fuel economy and having power when you need it, and both need a soft touch when working on them. Ask a Chevy guy about a Quadrajet and you'll hear the same things you hear here about the Solex, but the guy who has either in perfect working order will be the one getting the best overall performance out of his car.
#22 (permalink) | |
sorry just had to get that off my chest.And I'm not:"looking at things back wards" I sure know the difference between a single and a double barrel carb Double Barrel: Used on "S" engine's [high compression] ![]() Single Barrel: Used on "N" engine's [low compression]
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 07-10-2007 at 06:52 PM. |
#23 (permalink) |
Viking
Real Name: Hallgeir
The single barrel carb where used here in europe as Erick says on the 1.6N and 1.9N engines. These had lower compression than the "S"-engines, and they produced 68 and 75 HP. Used in Ascona and Manta, and the 1.9N also in the Rekord.
#24 (permalink) |
i think this may clear the mud a little
our US members and European members must remember that the cars imported to the US had to meet a whole different range of legislation the the original cars made over here so both parties can be right when looked at from outside the frame work of the small range taken to the US i have had 1.6 litre engined opels with the single barrel carb (on an S as well as an N ) they do exist they are out there and no the poor Americans did not get them
Copyright © 2003-2009 barry williams All Rights Reserved save praying to God for sunday today we pray to Nike and run like hell Last edited by tekenaar; 07-10-2007 at 07:53 PM. Reason: party's = party is . . . even there ROFL |
#25 (permalink) |
That may explain it, we only had CIH "S" carbureted engines here, 9.0:1CR (HC, flat-top piston) from 1968-70 and 7.6:1CR (LC, dished piston) from 1971-74! For 1975, we only had a 1.9E engine, 7.6:1CR with Bosch L-Jetronic FI . . .
