Real Name: Gerry
Thanks Gerry
"I don't know where we're goin', but there's no sense bein' late." Matthew Quigley |
Greenopelgt
Opel GT 1.1 Liter with duel Solex carbs
I have an original 1.1 L with dual carbs. I am out of town right now but I will respond ASAP. Hope this will help you.
Tom Adkins 1969 Opel GT 1.1 Liter Cincinnati, Ohio Last edited by tekenaar; 02-07-2008 at 07:32 PM. Reason: duel - pistols at dawn? ;-) |
Greenopelgt
Hoses on 1.1 duel carbs
That's a great illustration Otto has provided. If just checked my photo gallery and I have about 4 engine compartment pictures that may help until I get home sometime next week. I guess you just go to member photo gallery and click G and go down to greenopelgt and click on the picture to the right.
Tom Adkins 1969 Opel GT 1.1 Liter Cincinnati, Ohio |
Real Name: Gerry
Thanks Otto and Tom,
the brass tubing was missing on the front carb. It appears to be approx 5/16" in outside diameter. I am sure it is metric in size, but I think 5/16 will be close enough to shave to fit, as long as the wall of the tubing are thick. The lower intake connection may go to the rubber vertical tube from the valve cover and air cleaner assembly. There is another tube of about the same size from the air cleaner (5/16") that is still a mystery, though this one is far less crucial for the car to run without a vac leak. Tom, if you can send me a few close up pics of the original set up, it would solve this question as well(maybe a "T" in the line?). I appreciate the info. Otto, where did you get that illustration? The FSM that I have for 69 didn't have that one. Gerry
Real Name: Gerry
69 FSM vs.70 FSM
I looked in the 70 FSM and what a difference. I will definitely use this for tuning. However, in looking at my stash of 1.1 manifolds I noticed one for dual carbs without the solenoid. Just a plate where it should be. One of the vac ports of the driver's side is also eliminated. Was this from a Kadett? Could this be used in place of the solenoid one if the diaphram is worn? I have been told that the diaphram is impossible to find. What would be the difference in performance?
Gerry
That Diaphram ...
The solenoid is driven by a very rudimentary 'computer' and is there to allow much leaner jetting in the carbs by enriching the mix at WOT and idle.
If you have a manifold and carbs without that set-up ... then use it ... as there will be far better performance and power without it. Just be aware that the earlier Kadett carbs from manifolds that do not have the enriching solenoid are considerably different from the GT carbs. The GT carbs are basically sealed units to stop tampering with idle and fuel mix to comply with emissions. The earlier carbs are quite tunable in comparison.
#10 (permalink) | |
Italian opel owner
I also have a 69 1.1 Liter I have my carbs off right now but they are still on the manifold with the hoses still attached, Tom and I have disussed back and forth are 1.1's because theres not to many of them. I may have some pictures of it in my gallery for you take a look if not let me know and I can walk you through it over the phone or via webcam.
Mike,
Your Civic may have 1.6 Liters, But My Mountain Dew has 2. |
