I have one little problem with my carb. When I finished with adjusting screws (2 of them, 1- for gasoline, 2- for air) it is ok. Everything is fine, but after driving for a while, they loosen and the carb isn't working well. A solution how to fix this problem will be from a great help. PS: Coming Soon - this summer pics from my ascona!!!
Italian opel owner
Hmm depending on wether you want to keep that carb a while or not check to see if the carb is damaged where the screws go in and maybe try bigger screw or replace the carb or put a dab of an epoxy in there then set them to where you want them and just hold it there until it dries, i know its kinda redneck but thats all I coudl think of for you right now
Mike,
Your Civic may have 1.6 Liters, But My Mountain Dew has 2. |
You could try Blue Loctite if it is available to you, it will tighten up the threads but still allow you to turn the screw.
Just a thought: those screws should have a sealing o-ring, and depending on the carb's version !possibly! springs. Are these in place? Both these (o-rings and springs) add a good amount of friction that prevents the screws from backing-out...
