Unanswered: duel solex 35-PDSI with rich idle mixture
Thanks |
Italian opel owner
I have never dealt with mine of course I have never had my 1.1 running call ogts see if they can help or talk to Tom (greenopelgt) but I know that he's never adjusted his but he may know
Mike,
Your Civic may have 1.6 Liters, But My Mountain Dew has 2. Last edited by tekenaar; 02-26-2008 at 08:22 PM. Reason: delt? call gots? |
Hiding to Nothing ...
Check if the carbs you have are original O.E.C.S ones or have been replaced with earlier Kadett ones.
The O.E.C.S ones are not adjustable and run lean at idle - unless extra fuel leaks in through the solenoid ghizzmo between them. Make sure it is blocked off and not continuously dribbling fuel because of the ruptured diaphragm. I have the earlier, adjustable Kadett carbs ... after several months of fiddling and rebuilding have them still not working as well as before I started. ... bought a spare set of carbs to get jets out of so I could carefully drill them over-size with Holley jet reaming drills. May have to make some new jets - or solder them up and start again. MY 'fix' is to replace them with a SSD 40mm DCOM Weber!
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by tekenaar; 02-26-2008 at 08:25 PM. Reason: DOCM? |
