Unanswered: Aahhh Twin Solex carb bowls leaking 1.1 liter
It appears that he had coated the carb bowls with jb weld to stop pitting leaks. Well it did not work. Questions: I know the motor is a 1.1 . 1967 SI motor. T he carbs are solex.*How many different types of carbs were there for this motor? * Where do I find replacement bowls? *How do I identify the carb so I can obtain the correct parts? |
#3 (permalink) | |
. . . only way to compare "early" vs. "late OECS" dual carb 1.1 engines is . . . post "passenger-side" pics of carbs and manifold!
I would make sure the carb body is really bad and not a leak that can be repaired with gaskets. I never could get my 69 GT carbs to tune and switched to the earlier 67 carbs that didn't use the OECS ports and solenoid.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 06-25-2009 at 03:26 PM. Reason: clearer pic |
Oecs
Not only need the carbs and manifold to use these carbs but also the idle solenoid set up complete with a working 'computer'
Don't go there! Strong men go weak at the knees .... and lesser men have been known to break down in tears while trying to tune the OECS carbs. One thing to try is finding an early single carb off a 1.1 or 1.1S motor which have the same Solex model number in the manuals - but different jets and accelerator pump shot size. Two might be able to be converted for dual use. I have not ever done that - or even seen a 1.1 one carb unit! The Solex type is: 35 PDSI-2 and they may be used on some other German manufacturers motors - try Mercedes. OR use one of these - pic below.
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by tekenaar; 06-25-2009 at 09:49 AM. Reason: GTJim: Add Answer; OCES |
#11 (permalink) | |
That said, Kevin Fier (kevinfier) has had a running SSD setup on his wagon for several years now, ask him to point you in the right direction . . . this is his:
1.1 Solex 35 PDSI-2 NON OCS carburetor Needed
My carb bowls have pitted and are now leaking.
Does anyone one have a set for sale? Or a damaged set I can get the bowl from? Kenneth Winter 423-526-1328 Leaking in TN Last edited by klwinter; 06-25-2009 at 11:00 AM. |
#13 (permalink) | |
Help us out here . . . refrain from doing this, please! ![]() BTW, float bowls are cast as part of carbs and cannot be separated from carb body . . .
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 06-25-2009 at 03:34 PM. Reason: add images |
Opel Adventure # 77 NC
Real Name: Kevin
Ssd
Ken,
As Otto said, it is not that easy. I found my carb/intake on German ebay, was not cheap, but worth it to me. In addition to the carb/intake, you will need to fabricate throttle linkage, mine had the added difficulty of being an automatic, and needing the passing gear kickdown also. You might be able to use the later carbs from a 1.1SR w/ automatic, they did not use the same OECS setup, and did not have the solenoid & computer. HTH Kevin Last edited by tekenaar; 06-25-2009 at 06:24 PM. Reason: card/intake |
#15 (permalink) | |
Depends ...
Think it depends upon how that chart is read.
Looks to me like both the Model 31 Sedan and Model 39 Wagon came with the 11S motor standard and the 11SR motor as an option - either with a 4-speed or an auto as another option. So is Vickie's 1969 Kadett a Model 31?
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 06-25-2009 at 08:51 PM. |
#18 (permalink) | |
That said, and I can't recall exactly, but if yours is registered as a '68 here, the manufacturing date needs to be established and I'll bet it was September '68 or later, which would make it a '69 here in the US. Anyway, based on the best of my research available, the only 1.1 A/T cars ever produced were US-spec, 1969-year, 11SR, 4.11 geared, Model 39 Wagons . . . you couldn't option the "Wagon only" 1.1 A/T differently.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 06-25-2009 at 09:37 PM. Reason: More info |
#20 (permalink) | |
Then again, the FSM also lists the Model 93 Opel GT being available with both the 4-spd 11SR and the 19S with either tranny, when we all know the Model 93 was the 11SR engined GT and the Model 94 (not listed) was the 19S engined GT! Anyway, changed the chart to reflect the 11SR A/T option available on the Model 31 . . . for now!
#21 (permalink) | |
#22 (permalink) |
Back to the Subject!
klwinter - you couls see if you can find a VW Hot-up shop and ask if they have Weber 34 ICH or ICT single barrel carbs - or what ever they use to upgrade VW motors using single barrel carbs.
Have a look here to see what they are like - might even be able to by them there! Weber Carburetors, Conversion Kits - Pierce Manifolds Inc. Weber Carburetors, Conversion Kits - Pierce Manifolds Inc. HTH
