Old 08-07-2005   #1 (permalink)
OmegaRunner is on a distinguished road
Unanswered: 1.1SR Jets?
Does anyone know which main jets the 1.1SR uses?
Hope someone knows
greetings Johan.
Project: http://www.garaget.org/?car=4320
Daily runner and upcoming project: http://www.garaget.org/?car=4640
OmegaRunner is offline
Old 08-07-2005   #2 (permalink)
Info!
1967 Kadett Rallye 11SR twin carbs - Main Jet X117.5 ( strangly enough the same jet as used on the primary side of the 1969 1.9S carb - unless the 1969 FSM has a misprint and the main jets have been mixed up.)
1969 GT 1.1SR twin carbs - Main Jet X132.5
Hope that Helps
Old 08-07-2005   #3 (permalink)
It does, it definitly does!
But if the Kadett and GT had different jets, what about the hp of the engines? How much more pwer did the GT make?
Old 08-07-2005   #4 (permalink)
Same rated HP
The 66-67 Kadett Rally 1.1SR and the 1969 GT 1.1SR motors were rated at the same horsepower - 67HP (gross).
THe early Kadett twin Solex carbs were simple single barrel down drafts where as the 1.1L GT twin carbs had no idle adjustments and relied on a special "extra" idle carb with a computer controlled solenoid between them on the intake manifold.
Old 08-07-2005   #5 (permalink)
aha! Guess I'll be looking at a little more power then the old 12S engine then I'm upgrading to 10:1 or even 10.5:1 i compression aswell + I think I'll be running the 12S carbs with the orginial X122.5 jets if the SR had 117.5. Do you think that I can get past the 70hp mark? Or should I give some more fuel, say like X130 jets?
Old 08-07-2005   #6 (permalink)
spdkilz02's Avatar
spdkilz02
everything is possible as long as u have the money to fund it
Adam
spdkilz02 is offline
Old 08-07-2005   #7 (permalink)
What do you mean by that? I have the carbs, the material to weld an intake, a friend that can take a couple of mm of the head for a little bit of money so.. All I wonder is if the concept will make it? I know a guy that will help me fine tune the carbs and adjust the ignition aswell.
Old 08-07-2005   #8 (permalink)
Betta Carotene's Avatar
Real Name: Allan Wheeler
Betta Carotene is on a distinguished road
Isnt there a weber sidedraft manifold on the ad board for the 1.1? Seems like a 40 or 45dcoe can wake that motor up
73 Gt (RIP), 4 speed, 2.0L, 290H cam, weber, S-10 clutch w/ matched flywheel, sprint to a 2" pipe, Aluminum finned oil pan. SOLD!
70 Kadett Wagon 14k, 1.9L, Auto, weber
Betta Carotene is offline
Old 08-07-2005   #9 (permalink)
I saw that now, but 240US!? That's waaaay out of my budget! + I'll have to find a carb that will probably cost the same.. (+ I live in Sweden so..) For that kind of money I can get it registrered with a tuned C20NE. That's an 8 valve OHC, 2 litre engine. 116hp from the start, and fairly easy to get up to around 140-150hp.
