Unanswered: Air Filter Swap?
Can you put a paper style air filter on a solex carb that has the oil impregnated mesh air filter? I would like to clean up the engine bay a little by doing away with the old oil style and all of it's hose/air duct work with a regular paper style but would like to know if it would affect the performance or not. Thanks
It is better to die on your feet, than to live on your knees. |
Air Cleaner swap
Asking for trouble putting a paper element on the solex. The Solex is very prone to vapor lock from heat, hence the heatshield under the carburator, enclosed canister for filter and snorkel going thru the radiator support to supply cooler air to the system. Weber and holley can take the heat better if you are going to keep the solex keep the complete system and chrome it if you want it to look better
You can find an element that will fit inside the canister that is less restrictive than others which will help.
As long as I drive Opel I've never had a car that didn't have the paper air filter, and people that I know who had the oil type went over to paper with out any problems [they all have Solex carbs]
I'm not exactly sure I understand your question. All the Opels I've seen came factory with a paper element filter. The K & N style (cotton gauze sprayed with filter oil) you can swap as long has you can find another of the same size. As long as either will fit the housing you should be okay. Now if you are talking about the old oil bath cleaners then the entire breather will have to be changed out to a more modern filter style.
If you have the early GT filter with mesh all you have to do AFAIK is to swap the breather tops, not sure about the bottom part. Hope I haven't further confused you. Harold |
Filter elements . . .
As stated previously, GT canister element can be swapped for K&N E-2340 element . . . improves breathing!!
OK sorry for lack of info.
1970 1.9 the snorkel kit has a gauze type mesh in the lid/top portion of the canister and there was oil laying in the bottom of the canister. Enough oil that it looked just like the oil bath type on our old ford tractor. That is why I am thinking that it is the oil bath type. I am just starting to get this opel on the road after sitting for three years. I got it for my wife as a wedding gift for her. After spending to much time over in the "great sandbox" and working on my suburban it is time to get "her" car in road shape and eventually show shape. Please bear with me because this is all new territory for me every thing is soooo small
#9 (permalink) | |
The GT isn't small it's comfortable and ergonomic, you can reach everything. Use the search feature, it works really well and most questions have been asked already by somebody. HTH and Welcome Home, Harold |
Thanks Harold.
I was afraid of that just hoping that mmaaayyybbbbeeee that wasn't the case. The small vacum hose has been blocked off by the previous owner and I'll need to put a new nipple in place where the hole is to hook it up write (right . . . correctly?). Thanks again and it is good to be home.
It is better to die on your feet, than to live on your knees. Last edited by tekenaar; 04-18-2006 at 01:53 AM. |
#11 (permalink) | |
If you get one of the vacuum lines that has a thick wall then it will just fit in the hole, no need to rig something. There wasn't anything there from the factory to start with. Any decent autoparts store should have it. I think the thin wall stuff is usually prepackaged and is probably better suited for windshield washer hose.
Harold |
#13 (permalink) | |
Harold |
I think photo's are in order to make sure everyone is on the same page. Now I am confused as an 'innocent bystander'. Did Opel really offer an oil bath filter on the earlier GT's?
Steve "ever notice you are never done tinkering with the GT?" Never mind, I am WAAAY beyond tinkering now...[/SIGPIC] |
#15 (permalink) | |
Plus I am a little confused also I thought that I read in a manual that some GT's had an oil bath filter also.I could just brain fried from working with kids all day too. thanks for all of your all's help it is appreciated
#16 (permalink) | |
Cam-in-head?
Hades- there's a good chance the standing oil you found in your canister was put there by someone who didn't know it wasn't needed. I would try running the car with a cleaned and lightly oiled mesh filter, or paper filter if you change the cannister top (the bottom part is the same for both) and see what happens. -Kurt Last edited by Opelkurt; 04-18-2006 at 12:20 PM. |
Thanks Kurt
That is pretty much what I was going to do. Rebuild the carb and replace the fuel pump, change oil, gap points fix vacum lines and try her out to see what happens Thanks for everybody's input and help
#18 (permalink) | |
The top of the GT filter housing has mesh of some type in it preventing the installation of a typical paper filter element. If no one posts a pic I have one laying around somewhere that I might could post a picture of. Harold |
#19 (permalink) | |
Harold |
#20 (permalink) |
Very interesting, thank you! And you say these were on the early 69 cars?
Interesting tidbit to note. Thanks,
#22 (permalink) |
Real Name: Nickolas
Most stock air filter housings i have seen have not had this type of "filter mesh" in the top portion. Are they that uncommon? 69 models only? I just saw my first one today on a junker gt. I did not look at it in depth but could they be taken apart and cleaned out? I presently have a weber on the my 1972 gt but i was just wondering.
