69 rear axle grease fitting
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
Thread: 69 rear axle grease fitting
    pfj
    pfj is offline
    Member pfj's Avatar
    Dec 2018
    Maryland
    147
    The grease fitting on my rear axle does not look normal. It has a steel tail sticking out of the center where I am used to seeing a ball.
    Feb 2018
    Finland
    428
    AFAIK there is no grease fitting on the rear axle, could it be the rear axle vent that you mean ? https://www.splendidparts.de/kaufhau...0&languageid=1
    Member opeljohn's Avatar
    Sep 2003
    Springfield IL
    1,621
    The rear axle vent mentioned above is located on top of the axle housing on the passenger side. It may have been plugged at one time. This vent is a small plastic piece now being reproduced and sold by the fine folks at OGTS. I know all this because someone had plugged my vent. The new piece is a tight fit. I had to coat it in oil and use a 1x4x6 block of wood to put enough pressure on it to seat it.
    Feb 2018
    Finland
    428
    That's the later type of vent, the earlier type is a steel ball with a piece of tubing attached to it.
  7. #5
    pfj
    pfj is offline
    Member pfj's Avatar
    Dec 2018
    Maryland
    147
    That’s it. Thanks. Looks almost like a grease fitting.
