Valve size question...
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By First opel 1981
  • 1 Post By Viny Charb
Thread: Valve size question...
    Sep 2007
    Camarillo Ca.
    49
    Joel Rapose
    I am going to replace my stock 1.9 valves with the larger valves of the 2.0 cylinder head size... The catalog says the valves for the 2.0 head are 42 mm and 37mm.....I already own a new set of 39mm intake valves for a 1.9 head.. Could I use the new intake 39mm valves as exhaust valves...that way I would only have to buy the 42mm valves for the conversion ??
    That would mean that my exhaust valves would be 2mm larger than normal 2.0 exhausts...will this work ? or might the exhaust valves made differently material ? I know the exhausts run at much greater temperature... it's just that I already have the valves... How about the closeness of the edge of the valves...maybe too close together ?
    Joel
    Apr 2003
    Portland, Oregon
    8,293
    Quote Originally Posted by jrapose View Post
    Joel
    Exhaust valves take a higher heat load than intake valves. I'd advise to not use intake valves as exhaust valves.
    kwilford likes this.
    Calgary, Alberta, Canada
    5,308
    5
    No. Intake valves will not survive the heat that exhaust valves endure.
    You might also consider installing hardened exhaust valve seats to match the new valves (and 37 mm is usually big enough).
    The 42 mm intake valve is only 1.65". That is better than the stock 1.574" (40 mm) intake valve, but not a significant upgrade, given the cost and work. Most of the serious CIH engine guys here suggest intake valves should be at least 1.75", preferably 1.85", with appropriate unshrouding of the combustion chamber to be done. That might be more easily achieved using cut-down Chevy 11/32 stem valves and matching valve guides, unless you can source larger Opel intake valves.
    JM2CW
    Working on a bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT, and I just bought a 28,000 mile Garage Find GT to work on next...
    1000 Post Club Viny Charb's Avatar
    Oct 2007
    Ontario Canada
    1,294
    When I rebuilt my 1.9 engine to 2 L spec i used the larger 2.2/2.4L 45mm intake valves with the 2L 36mm exhaust valves.
    1. Question For Anyone Who Has Upped The Wheel Size
      By VertZ24 in forum 3D - Wheels and Tires
      Last Post: 1 Week Ago, 11:58 PM
    2. Valve Cover Bolt Size
      By Ooooner in forum General Discussions
      Last Post: 12-23-2014, 10:21 AM
    3. 14 inch rims and tire size question.
      By Knorm65 in forum 3D - Wheels and Tires
      Last Post: 06-23-2014, 09:18 PM
    4. Valve keeper question (and valve seals)
      By airbob01 in forum 6A - Engine Mechanical
      Last Post: 08-25-2004, 02:02 PM
    5. New Tires? Size question.
      By BuickNick in forum Manta
      Last Post: 04-18-2003, 10:22 PM
