"Failure to start": 265 chevy pistons and valves
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Like Tree31Likes
Thread: "Failure to start": 265 chevy pistons and valves
    Jan 2020
    When making this conversion, did anyone experience "failure to start" issues? and if so, how was it resolved.
    All parts of the equation are covered, ((timing marks all on -- great compression (all 150 or better), great spark, and gas getting into the cylinders))
    Does not even attempt to start
    Spofford, NH
    13,135
    Bob Legere
    Quote Originally Posted by ronaldwright View Post
    There’s nothing physically would prevent the engine from starting, presuming machine work is done correctly.
    Generally, no-start conditions on a new build boil down to one of three problems.
    1)cam timing
    2)fuel delivery
    3)ignition timing and/or no-spark condition
    Fuel delivery is easy to diagnose. Whether you have spark or not is easy to diagnose.
    Proper spark timing and cam timing take a bit longer to figure out, but are simple enough.
    guyopel and dpre like this.
    Opel Rallier since 1977
    Aug 2006
    Afton VA
    844
    If you are getting 150 psi cranking compression, then your cam timing must be good, and the piston seal is adequate to good.
    Look at the plugs. Are they wet and do they smell of gas?
    And how are you testing spark? If you are looking at a spark jump a spark plug gap in open air that test is in no way valid to check that the spark is strong enough. It takes many times higher spark voltagae to jump the spark plug gap in a compressed fuel-air mixture than in open air. You have to connect a spark plug wire to a screw driver and put the screwdriver shaft near metal (like the body or valve cover) and the spark should jump 1/4" or more in open air.
    Timbo and dpre like this.
    Apr 2003
    Portland, Oregon
    8,698
    Most common mistake, distributor firing is 180 degrees off
    Also, make sure you put the rotor on the dizzy shaft.
    opelbits, tomking and dpre like this.
  7. #5
    Detritus Maximus opelbits's Avatar
    Jul 2002
    St. Louis MO
    2,035
    No ground cable would be a problem, too. I forgot that when swapping motors one time.
    "No, it's not fiberglass."
  8. #6
    Jan 2020
    I have tested the spark, both in the open air and will with the timing light. both show consistent firing -- they are not missing. Spark plugs were replaced twice during the testing process. On the off chance that the plugs had gotten fowled. There is a strong smell of gas in the cylinders if you pull the plugs and turn the engine over. -- Also, if you push it far enough out of time, the fire shooting out of the corroborator will travel halfway to the garage ceiling -- got my attention the 1st time that happened.
  9. #7
    Can Opeler Knorm65's Avatar
    May 2014
    Norman, Oklahoma
    3,146
    Kyler Norman
    5
    It’s most likely 180° out.
    Swap plug wires 1 and 4, and swap 3 and 2 then try.
    kwilford and dpre like this.
    "Kara," 1972 Opel GT Targa, Welded Doors, Rhinolined, 40 DCOE SSD, Working GM AC
  10. #8
    Calgary, Alberta, Canada
    5,549
    5
    Are you SURE that the distributor is not 180 degrees out? That sure sounds like it.
    It is a very common mistake, since the cam timing is set with #4 at TDC in firing position, NOT #1 as most folks might think. But the distributor install instructions require that the crank be rotated 360 degrees, which puts #1 at TDC in firing position. Easy to check, by moving the plug wires so that #1 is the top left (versus the bottom right) on the cap, and follow the firing order clockwise: 1 - 3 - 4 - 2 . Or pull the distributor, set the engine to firing position on #1 (valves closed, ball lined up w/ timing mark) and reinstall the distributor. Then try rotating the distributor as you try to start it.
    opellane and dpre like this.
    Finishing up a bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT
  11. #9
    Senior Contributor Site Supporter opellane's Avatar
    Apr 2004
    Goshen, NY
    1,429
    Mike
    I agree with Keith, and the others... have spark,, have fuel,,, and it's a Flame thrower LOL Holy Cow Garage ceiling .. 180 out
    If it was me , I'd pull the Dist. Do a 360 rotation, reinstall with #1 TDC.. I think this way you will have more adjustment of the timing, as the vac. can will have more adjust too.. JMHO
    So with Chevy 265 Pistons and Valves .. is that a 2.0 engine,, Interesting ??
    dpre likes this.
    MIKE
    1972 Opel GT, 1969 Opel GT, 1973 MGB,
  12. #10
    Spofford, NH
    13,135
    Bob Legere
    Quote Originally Posted by opellane View Post
    Call it an ‘Americanized’ 2.0.
    European 2.0 liter is 95 mm bore, making it 1979 cc’s.
    With standard-bore 265 Chevy (3.75”/95.25 mm) pistons, you would have 1989 cc’s.
    Stock Opel 2.0 liter valves are 42 mm intake (1.65”), and 36 mm exhaust (1.42”).
    Chevy 265 valves are 1.72” intake, and 1.50” exhaust.
  13. #11
    Apr 2004
    Goshen, NY
    1,429
    Mike
    The Chevy Stock 265 Pistons will fit the Forged stock Opel Rods?? Interesting?
    The Stock Chevy 265 I/E Valves/springs and Retainers , install new valve guides "" Will all fit the Opel Cylinder Head" ?
    Bob, Do you have a thread on how to do this Mod. ?? Interesting
    dpre likes this.
    MIKE
  14. #12
    Spofford, NH
    13,135
    Bob Legere
    Well, it’s not THAT easy. But it’s been done for 40+ years so it’s nothing new.
    The Chevy pistons have a .927” pin diameter. Opel uses 23 mm (.907” basically) so you need to have the pin end of the rods bored out.
    Of course the block must be bored .090”, which is typically done in two passes so it costs more than a normal re-bore.
    To install the valves, it requires installing valve guides with a reduced ID. Opel uses 9 mm valve stems (.354”), but the Chevy uses 11/32” (.341”).
    The Chevy springs are generally too tall for the Opel head casting. Over the years a lot of people have used short (but bigger OD) Pontiac 400 valve springs and retainers. This requires machining the spring seats both in depth and OD.
    I don’t have a recipe or thread on this as it’s too old-school for me, the last time I did a head like this was in the late 1980’s. Much better ways to do it now, although they do cost more.
    I have threads on my preferred methodology to do a big valve head but it uses all aftermarket racing-quality parts, not the stock Chevy stuff. You’ll have to search for it because it’s been years since I’ve written it and I have no idea what the title was or when I did it exactly.
    Mercougary and dpre like this.
  15. #13
    1000 Post Club Vincent's Avatar
    Oct 2007
    Ontario Canada
    1,502
    As already mentioned, This old info that's been written about and done many times on this forum.
    dpre likes this.
    1971 Opel GT - full rotisserie restoration - painted modern corvette yellow -
    Orig1.9L > 2L short block, 45 & 36mm valves, ported head, Isky OR-66 hyd cam, ported welded tented intake, Weber 38 dges, pertronix ignition, aluminum flywheel with S-10 clutch, 4 speed trans . Dual core Honda radiator, with 14" Permacool fan. Stock wheels & trim, 205 60 R13 BFgoodrich Radial t/a tires, 1" lowing front spring, 3/4 front, and 5/8 rear stabilizer bars.
  16. #14
    Jan 2020
    I tried this, and the car started -- months of frustration and it turns out to be a rookie mistake--
    Thanks everyone for responding -- you have really made my day.
  17. #15
    RunOpel dpre's Avatar
    Mar 2019
    Port Orchard, WA
    709
    Dan
    I would bet every Opel owner has had their distributor 180 degrees off and had the experience of
    fuel shooting out the carburetor like a volcano But it sure is a good feeling once you correct
    it and get it to start and run smoothly
    Glad to hear you got it corrected.
    Keep on Opeling rubber side down and shiny side up
    Make a difference and help someone today
    Dan
  18. #16
    Member Mercougary's Avatar
    Mar 2017
    Tacoma, WA
    223
    Gary
    I don’t have a recipe or thread on this as it’s too old-school for me, the last time I did a head this was was in the late 1980’s. Much better ways to do it now, although they do cost more.
    https://www.opelgt.com/forums/opel-e...opel-head.html
    https://www.opelgt.com/forums/opel-e...html#post13287
    https://www.opelgt.com/forums/conten...alve-head.html
    dpre likes this.
  19. #17
    Apr 2003
    Portland, Oregon
    8,698
    Wow, if only someone had mentioned this in the first 4 replies....
    rrossjr, Vincent and dpre like this.
  20. #18
    Spofford, NH
    13,135
    Bob Legere
    I thought I did in my first reply?
    dpre likes this.
  21. #19
    Oct 2007
    Ontario Canada
    1,502
    Lol
    Guess no one was listening ....
    dpre likes this.
  22. #20
    Apr 2003
    Portland, Oregon
    8,698
    You did, kind of.
There are currently 3 users browsing this thread. (0 members and 3 guests)
