Chasing vacuum leak, carb cleaner kills engine? - Page 6
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 6 of 6 FirstFirst ... 23456
Results 101 to 108 of 108
Like Tree36Likes
Thread: Chasing vacuum leak, carb cleaner kills engine?
  1. #101
    Jul 2015
    Southern California
    577
    Tom
    Enjoy, thanks for posting your success
  3. #102
    Mar 2018
    San Pedro, CA
    85
    Matt Basura
    Awesome! If you get a chance, let us know what it vacuum level is at idle. Always good to have more data....
    Vacuum at idle measured at a port on the tree is zero. I also checked it with the DIY smoke machine and no leaks.
    I,ll drive it around more this weekend. Fingers crossed it is finally licked.
    Matt
    Sent from my iPad using Tapatalk
  4. #103
    Nov 2007
    Cöllingswööd, NJ
    13,201
    Gördö
    6
    Whaaaaaa...?
    Shouldn't vacuum be at it's highest at idle when measured at the manifold?
    I have an analog vacuum gauge in my dash and when I'm idling it's somewhere around 15Hg. I've had vacuum gauges in my dash for 30 years and they always read somewhere around 15Hg's at idle.
    It's when you step on the gas and let air in via the throttle that your vacuum drops to zero.
    This is the VDO kind that I always used in place of the clock:
    And this is the type, on the right, that is in my car now:
    The needles always stand straight up at 15Hg on both at idle.
  6. #104
    Can Opeler Knorm65's Avatar
    May 2014
    Norman, Oklahoma
    3,086
    Kyler Norman
    5
    Whaaaaaa...?
    Vacuum should be around 17-22inHG at idle (you have a cam so 15 is fine). Vacuum is maximum under deceleration when you close the throttle at high rpm. It is only zero at WOT.
    If this guy is reading 0 at idle on the manifold then the manifold port needs to be cleaned out as it is completely clogged.
    The car would not be running with 0 at idle from the manifold.
    SpringGT and The Scifi Guy like this.
    "Kara," 1972 Opel GT Targa, Welded Doors, Rhinolined, 40 DCOE SSD
  7. #105
    Mar 2018
    San Pedro, CA
    85
    Matt Basura
    Crud! Or I’ve killed another HFT vacuum gauge. I will check again tomorrow.
    Matt
    The Scifi Guy likes this.
  8. #106
    Opel Rallier since 1977
    Aug 2006
    Afton VA
    545
    Quote Originally Posted by mbasura View Post
    A HFT tool FAILING? Impossible! LOL
  9. #107
    Mar 2018
    San Pedro, CA
    85
    Matt Basura
    Mea culpa. The HFT vacuum gauge turned out to be fine. I had the hose connected to the vacuum advance port on the carb, which I think explains it (the car had only been running a minute or so when I took the measurement).
    Moved to the tree, the the gauge read about 17. The needle bounced a bit but was pretty steady.
    Matt
    Sent from my iPhone using Tapatalk
    Vincent likes this.
  10. #108
    Aug 2006
    Afton VA
    545
    Hey, that is a pretty good number! Tnx.
There are currently 4 users browsing this thread. (0 members and 4 guests)
