When you upgrade to FI do you use the same cam ?
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
Thread: When you upgrade to FI do you use the same cam ?
    Sep 2007
    Camarillo Ca.
    49
    Joel Rapose
    I am planning to upgrade to upgrade...but wondering about the camshaft ?? I always thought the cam used was different than one used for a carbureted engine> ..... at least when I look in the Summit catalog they appear to use different cams... yet I only see standard cams offered for Opel engines...no FI cams offered... Thoughts ??
    3000 Post Club norbertone.gt371's Avatar
    Dec 2009
    Germany/Bremen
    3,711
    Norbert
    No Thoughts only facts
    16N - A
    16S - A
    19S - M (for Sweden Letter B)
    1,9N - A
    1,9E - H
    20N - K
    20S - K
    20E - R
    Early engines have three bearrings and later four bearings.Also difference in massiv and hydro lifter curve.
    Feb 2018
    Finland
    174
    The difference in hp is very small between a FI cam and a carbureted stock cam. For example, a 20S with a K cam has 100hp DIN vs the 110hp DIN R cammed 20E where the FI system makes more difference than the cam. Besides, the K profile is also used in the fuel injected 30E six cylinder engine as well as in the 20S and 28H/30H carbureted engines.
    Jun 2006
    N.H
    233
    Cam
    Joel it appears your looking to build a big valve head for this and other posts. I recommend upgrade your cam along with the valves. Remember you are building a motor , all the systems need to work together. There is a ton of info on this site so have fun . The cams we got in the US are all about the same as far as performance. Your problem is going to be determining what EFI your going to do and will it be better for you .
    1. Do any of you have the same problem I have driving my GT at night ?
      By OpelJim in forum 1C - Lighting and Signal Systems
      Last Post: 07-18-2016, 03:17 PM
    2. Which Browser do you use?
      By Gary in forum Polls
      Last Post: 01-19-2010, 09:34 AM
    3. What air compressor do you use??
      By EastcoastOpel in forum General Discussions
      Last Post: 11-11-2008, 09:20 AM
    4. what rear end do you use with the v6 swaps ?
      By ricracer in forum Engine Swap Forum
      Last Post: 04-30-2003, 11:02 PM
