Gordo Goes FI in the GTX - Page 5
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 146
Like Tree126Likes
Thread: Gordo Goes FI in the GTX
  1. #81
    Dec 2009
    Germany/Bremen
    4,093
    Norbert
    Holy Cow Norbert. You stayed so humble and un-modified and not very new for many decades and now you are going wild with GT modifications and now a crazy wild Calibra!
    I can't keep up with you!
    Gordon
    I hope the time is with me,so I have only from day to day!So I will have fun and not lay arround in bed.
    Without the help of my friends,maybe I would have give up long time.
    I didn`t know
    I think the Calibra will be only a Garage Queen as she was all live.
    Btw.It will be the second Calibra I own. The first 1992 was real Lopez car
  3. #82
    Nov 2007
    Cöllingswööd, NJ
    12,986
    Gördö
    6
    Fuel Return line kit
    Running a fuel return line is one of the next jobs, so I thought I'd look to see if there was a kit of some sort. JEG's had this incredibly simple idea:
    https://www.jegs.com/p/Moroso/Moroso...43759/10002/-1
    Gosh that's simple! No messing with your tank, put the return line in your filler neck. This probably wouldn't work for me, but maybe it could. My fuel inlet is only a few inches above the top of the tank, complications might arise. But this would probably be a good solution for you normal GTers.
  4. #83
    Feb 2018
    Finland
    313
    One way to solve the return line to tank connection: http://www.fuel-pumps.net/fuel-tank-...d-fitting.html
    The Scifi Guy likes this.
  6. #84
    Feb 2018
    Finland
    313
    Double post.
  7. #85
    Feb 2018
    Finland
    313
    Double post.
  8. #86
    611
    Jun 2016
    UK, Bournemouth
    25
    Andy
    Quote Originally Posted by Commodåren View Post
    One way to solve the return line to tank connection: Fuel Tank Bulkhead Fitting from Fuel-Pumps.net
    Didnt read your whole thered as it was a bit long! Not sure if you have run the lines yet but i used Goodridge hardline and fittings for my A series injection install, followed the original fule line route and they do bulk head fittings.
    http://www.theopelproject.com/wp-con...0520121453.jpg
    http://www.theopelproject.com/wp-con...0520121454.jpg
    Thought it might be of interest to you.
    Andy
  9. #87
    Nov 2007
    Cöllingswööd, NJ
    12,986
    Gördö
    6
    Hey! Thanks a lot! I've been hoping to get some ideas on line routing and maybe replacing my present single metal fuel line with a neatly installed dual pair. I'll look through your set up and see if I can do something similar.
  10. #88
    611
    Jun 2016
    UK, Bournemouth
    25
    Andy
    If you need any more pics let me know, not sure what i have on the blog The Opel Project | The Mission – to get to the nurburgring in the Opel but have taken a few. Very easy to install and not that expensive (even in the uk!) so probably nice and cheap in the US. (https://www.goodridge.co.uk/collecti...inium-hardline) they do loads of fitting. routed mine from the boot with bulk head fittings, followed the standard route, then came up into the engien bay, used a bracked for 2 more fittings and then onto the braided lines for the throttle bodies, fuel filter and pressure regulator in inside the engien bay.
    P clipped the pipe and as long as its a bit warm you can work with it easily. Let me knwo if you want some pics of boot fitting and engine bay.
    andy
  11. #89
    Nov 2007
    Cöllingswööd, NJ
    12,986
    Gördö
    6
    It's going to be a nice weekend and I have to start major disassembly and fluid draining to make way for the fuel injection conversion and head replacement on my car. Drain the tank and remove all vestiges of the current fuel delivery system. Remove the carb/manifold/linkage/pedal. Drain and remove the radiator and remove the current hoses/thermo assembly.
    I have a fancy custom fuel tank and I'll have a refurbished and chromy FI system, but all the stuff in between was fairly pedestrian, so it's time to pick up my game. I plan on replacing everything with AN fittings and new widgets.
    New 2.4 head with dished instead of domed valves to reduce compression, plus a Cometic 2mm thick head gasket to also reduce compression.
    My nice 3-core copper heavy duty radiator has served me very well, but it's an ugly oem black dented up eyesore, even with it's cool stainless top cover, so I'm replacing it with one of the new 3-core aluminum OGTS radiators. Long waiting list for those.
    I tentatively plan on routing the computer wire harness through the heater box area. I have the heater removed in favor of a relocated aftermarket heater, so that whole heater box area is just a pathway for the flow through ventilation, which I pretty much keep closed all the time, so I might as well use it for something useful. I had made a chromed aluminum cover plate for that area, but it's not holding up very well, so that has to go anyway. I made a diamond plate block off plate for the rectangular heater box opening above the passenger footwell and I plan on routing the wire harness through that plate and mount the computer to the plate itself.
    My head is done and Charlie is going to send me that and just about everything needed to complete the FI install. I have to test fit all that stuff and make mountings and paths for stuff and then send some stuff off to the chromers for chroming. I'm figuring on a 2 month time frame from now before final hook up and the first turn of the key.
    soybean likes this.
  12. #90
    Nov 2007
    Cöllingswööd, NJ
    12,986
    Gördö
    6
    Cometic gasket
    My 2mm thick Cometic gasket arrived yesterday. I'm not impressed:
    Cometic gasket (1).jpg Cometic gasket (3).jpg Cometic gasket (4).jpg Cometic gasket (2).jpg
    It appears to simply be 5 layers of stamped sheet metal with some corrugations held loosely together with the rivets at 4 external tabs. No printed on seal traces, no spongy substance of any sort at the timing cover, just a bunch of layers of sheet metal. The center, top, and bottom layers are black with some special sort of next-to-nothing-thin black paint-like stuff, with 2 intermingled layers of stainless steel. That's it.
    It will NOT be interesting to see how this assemblage performs.
    Having not read the instructions yet, I presume that I will use RallyBob's method of spraying it with copper spray before install.
    Anyone have experience with these?
    Tips?
    Tricks?
    norbertone.gt371 likes this.
  13. #91
    Spofford, NH
    13,005
    Bob Legere
    Tips?
    Tricks?
    Relax Gordon, most late model engines use MLS gaskets. Yes, the layers are ‘loose’. This is normal.
    Some OEM gaskets come with a urethane coating on them. The Cometics do not.
    I like using either the copper spray or Hylomar sealer. Depends what I have handy.
    A little extra sealer at the front doesn’t hurt, however keep in mind the raised areas of the gaskets are what create the ‘crush’ and aid in sealing.
    soybean and The Scifi Guy like this.
  14. #92
    Apr 2003
    Portland, Oregon
    8,506
    I think Gordo is just unimpressed because it's not chrome with tricked out red highlights.
    GoinManta and The Scifi Guy like this.
  15. #93
    Nov 2007
    Cöllingswööd, NJ
    12,986
    Gördö
    6
    Redneck Gas Station
    I had almost a full tank of fresh premium gas in the tank, but I'm planning on major fuel line mods so it had to come out.
    What to do with it all?
    Hmmmmm......
    GoldGT, soybean and kwschumm like this.
  16. #94
    Feb 2018
    Finland
    313
    Are you going to use an in-tank or external fuel pump ? Baffles for keeping the fuel flowing to the pump without sucking air when fuel level is low or a surge tank ?
    https://images.app.goo.gl/tYRSzUvqqUABSoFx7
  17. #95
    611
    Jun 2016
    UK, Bournemouth
    25
    Andy
    Are you running 2.4 bottom end? as did read on a few threads about punching 2 extra holes in the head gasket on the exhaust side to reduce heat? not sure if this is something that needs to be done or if some people prefer to do it? im sure Bob will be able to give his view on it.
    Andy
  18. #96
    Jul 2015
    Southern California
    516
    Tom
    Tips?
    Tricks?
    I have only installed one and only one MLS gasket in my life, not close to the experience Bob has had with them. I used the cork gasket and treated it like any other head gasket with the exception of adding a very thin layer of grey silicone gasket sealer between all layers ONLY above timing cover being EXTREMELY vigilant not to interfere with the hole in the gasket for the oil galley. It seemed like some sort of sealant needed there. Hopefully I didn’t do anything wrong. So far so good after 10k+ miles. What, if any feedback have you gotten as far as the what surface smoothness is on both your block & head, if any? For all I know other people have had success using them with a 70-75 RA finish on the surface, good enough for any other standard head gasket. I’m curious if you’ve heard of anyone else getting away with that.
  19. #97
    Nov 2007
    Cöllingswööd, NJ
    12,986
    Gördö
    6
    As with women, it looks pretty good stripped.....
    Fuel tank and coolant system drained. Radiator removed. Carb system removed. Radiator and engine flushed with water. Various wires and connectors disconnected.
    That's it for today.
    Tomorrow I'll pull the head and we shall see what we shall see.
    Stripping of the engine compartment in preparation for FI (1).jpg Stripping of the engine compartment in preparation for FI (2).jpg
    Yeah, 2.4 head and block.
    I don't think the punching the holes in the gasket is as necessary on a raised port head as it is with an inline 2.0 head. I'm not anxious to punch holes in this expensive gasket. Unless Bob says I absolutely MUST do it, I ain't doin' it.
    As far as the degree of flatness, all I can say is that Charlie says that his shop is the best in his area and other shops send their milling work to them.
    External fuel pump. I really don't know if my tank has baffles or a "wall". I kinda recall that it does and I know for sure that it doesn't have the spaghetti pot. I might be wrong about the baffle. What good does it do to have baffles if you run out of gas? If you're out of gas, you're out of gas and the pump will suck air one way or the other. Or does a baffle prevent that gas from being used and holds it so that the pump can keep recirculating gas back to the baffle area? I would think that if the gas is being consumed by the engine, it will eventually use it all up one way or the other.
  20. #98
    Nov 2002
    Reidsville N.C.
    2,299
    W Jarrell Young
    If I remember correctly the extra holes came into play for the smaller engines, and it was used to keep the exhaust heat from cracking the head, so I did it on mine back in 05. I don't and won't have the power you have with yours, plus I wasn't using a metal gasket. Punching a hole in your gasket would deform it in my opinion. I'd leave it be. Jarrell
  21. #99
    Spofford, NH
    13,005
    Bob Legere
    Unless you have a proper punch (Roper-Whitney type) for sheet metal, you’re better off leaving it alone before you cause irreversible damage to the gasket.
  22. #100
    Feb 2018
    Finland
    313
    Baffles, swirl pots or surge tanks are needed to prevent that the FI fuel pump sucks air when the fuel is sloshing around during acceleration or turns, which in a worst case can destroy the engine when it suddenly runs lean. But if you get your foot out of it and just cruise around and always keep the tank at least half full, you probably can get by without them.
    Swirl pot from a Vectra B in a Manta A tank: http://www.opel6070club.com/loiskelevyt/index.htm
    First opel 1981 likes this.
