Throttle linkage
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
Like Tree4Likes
  • 2 Post By tealcarver
  • 2 Post By The Cub
Thread: Throttle linkage
    pfj
    pfj is offline
    Member pfj's Avatar
    Dec 2018
    Maryland
    153
    Throttle linkage
    Can someone point me to a good thread on the throttle linkage. Are there bushings for the 2 ball and socket joints? A bushing at the firewall? Other adjustments?
    I kept the carpet padding out from behind the pedal. Do folks take out the entire pedal box? The first inch or two of throw is dead. Do you make an adjustment at the fork on the carb?
    Thanks
    Nov 2002
    Reidsville N.C.
    2,894
    W Jarrell Young
    Quote Originally Posted by pfj View Post
    Thanks
    https://www.opelgt.com/forums/6a-eng...-bushings.html (from the search function on the home page) HTH, Jarrell
    1000 Post Club tealcarver's Avatar
    Dec 2002
    Fallon, Nevada
    1,539
    Sounds like bushings to me. Call Gil at OGTS, they will get them to you quickly and because they are polyurethane, I doubt that you will ever have to replace them again. The old ones are about 50 years old, bound to wear out over that period of time. I think this will end all the other problems related to the throttle, I know it fixed mine.
    soybean and MikeNotigan like this.
    71 Chrome Yellow GT
    Jul 2015
    Southern California
    626
    Tom
    Your throttle grommets are probably shot as previously mentioned https://www.opelgtsource.com/search?...rottle+grommet
    There’s a small wire clip on the female ball socket that keeps the male ball from the rod from popping out. I’d recommend replacing throttle grommets first then see where you’re at, if those are actually missing that’d be a large part of the problem. Once you find the little are clips the rest is trial and error if you need to further adjust. HTH
    soybean and SoCalOpelGT like this.
