Opel Checklist
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 18 of 18
Thread: Opel Checklist
    Opeler Yoda's Avatar
    Sep 2003
    New Roads, LA
    66
    Brian Pangburn
    Opel Checklist
    I recall seeing an Opel Checklist years ago with 10 or 20 things that should be done to all Opels (e.g. gas tank vent lines, headlight wiring, etc.). I think it was sort of a checklist for new Opel owners. Getting ready to start spending some time with my GT again and thought running through that list would be a good place to start in terms of maintenance.
    Anyone else recall seeing this list and/or have a link to it?
    7,000 Post Club wrench459 (R.I.P.)'s Avatar
    Jul 2005
    Milner, GA.
    11,747
    Dan
    12
    Here's a general checkout list that we use at the shop.
    UPDATED 30 POINT SHEET 2011.pdf
    Sep 2003
    New Roads, LA
    66
    Brian Pangburn
    Thanks Wrench. That is a great list to have for any car and I've saved a copy of it. There was an Opel (GT) specific list floating around at one point. It had a list of items (some potentially dangerous) that should be checked on every GT.
    Member 06Charger's Avatar
    Mar 2007
    Virginia
    143
    Anthony Seal
    Is this what you are looking for?
    GT "Things to Know"
    1970 Opel GT
    1937 Pontiac Sedan
    1948 Studebaker Pickup
    1948 Opel Olympia
    1964 Chevy Impala Convertible
    1970 Opel GT
    1986 Dodge Conquest
    2014 Dodge Durango
  7. #5
    1971 Opel GT k1400's Avatar
    Jan 2007
    Harrison Township, MI
    198
    Ken
    Try this link:
    Opel GT Source --- The Mechanic
    OGTS calls it Winterizing, but to me it looks like a good list in general.
    I will fight 'til I am dead, a winged helmet on my head.
  8. #6
    UngerDog ungermm's Avatar
    May 2004
    Pleasanton, CA
    1,277
    I did a search and couldn't find the reference I think you're looking for. From my memory there was somewhere around 10 things to do or upgrades to get the GT up and running and more dependable.
    Off the top of my head in no particular order, they included:
    Installing a Weber carb (preferable with electric choke)
    Installing a radio shack ignition relay
    Replacing the rubber brake lines
    Rewiring the headlight harness
    Draining the gas tank of old gas, removing or punching through the tank sock, and replacing the fuel filter
    Replacing the mechanical fuel pump with an electric one
    Replacing the stock points with electronic ignition
    Replacing the gas tank vapor lines
    Replacing the oil and coolant
    Replacing the stock alternator with a high output alternator
    Priming the oil pump
    Replacing the rack boots and/or front end bushings (maybe?)
  9. #7
    Aug 2004
    Planet Earth
    1,494
    If the mechanical fuel pump is working well as it is, there's no need to swap it to electric.
  10. #8
    Sep 2003
    New Roads, LA
    66
    Brian Pangburn
    06Charger, that might have been it or at least a current version of it. I recall a B&W one pager in PDF or DOC format, but it had to have been at least 5 years ago if not longer so I might be imagining that. I think its the same one ungermm recalls. Fortunately, I've already done most of those things at one time or another.
  11. #9
    Jul 2005
    Milner, GA.
    11,747
    Dan
    12
    I'm going to BMW(bitch,moan and whine) for a second.
    So far I've not seen the max. ball-joint deflection spec.
  12. #10
    Jul 2005
    Milner, GA.
    11,747
    Dan
    12
    I stand corrected
    "Max. axial play of all Opel vehicle lower ball joints is .080 inches.
    New lower joints have axial play of .020 inches or less." as per Mr Chilton.
  13. #11
    Senior Contributor GoldGT's Avatar
    Oct 2002
    The Villages, FL
    4,801
    List off the top of my head.
    Change Engine Oil
    Change Tranny Oil
    Change Rearend Oil
    Change coolant and flush system
    Fix Headlight wiring
    Install starter relay
    Clean all connectors at the fusebox
    Clean all connections in the engine bay including the grounds
    Check the operation of all lights
    Check wipers and wiper motor
    Lubricate the headlight mechanism and cable to avoid damage to a "dry" system
    Replace the 3 rubber flex lines in the brake system and check the hard lines for rust.
    Replace the brake fluid
    Verify the operation of the brakes at all 4 wheels.
    Check tightness of front wheel bearings and re-grease.
    Check all ball joints and tie rod ends for wear.
    If they are very old....replace the shocks
    If they are very old....replace the tires
    Replace all hoses associated with the fuel tank vent system
    Check all muffler system hangers
    Replace the "V" belt(s)
    Check the distributor and either replace the points or put in the pertronix
    Replace the spark plug wires
    Drain old gas and do the fuel sock removal
    Replace the fuel filter
    Check all rubber bushings in the suspension system including panhard rod.
    I'm sure there is something I have missed, but not a bad start for car that's been sitting for an extended period of time. The brakes are the most important. If a car won't go it's no big deal but if it won't stop you could be in big trouble.
    '73 GT,5spd,Recaro,EDIS4 2.2 EFI MegaSqrt, Ali Flywhl w/S10 Clutch, Elec Fan, Roller Rockers, Venolia Pistons, 6 Cyl Intake w/ Custom Injection, 15" Wheels,F&R Sway Bars,2" Exhaust,1" Sport Spring,Koni Reds,Wilwood Brks,3:90 Gears & Gripper LSD,Rear Disks,Ali Radiator,Hse of Colors - Kandy Pagan Gold.
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35i BMW Z4
    '15 BMW M4 '11 BMW 335ix '04 Ford F150 SVT Lightning
  14. #12
    Apr 2003
    Portland, Oregon
    8,572
    Change Engine Oil
    Change Tranny Oil
    Change Rearend Oil
    Replace the 5 rubber flex lines in the brake system and check the hard lines for rust.
    Check battery connections and cables. Replce if old.
    Replace fusible links and resistor wire.
    And I know this sounds silly but check the steering wheel to make sure it's secure (and check horn).
  15. #13
    Resident Curmudgeon Opelmel's Avatar
    Jul 2005
    Omro, WI
    1,395
    Mel
    5 brake lines?
    I thought that there were only 3 rubber lines. Am I missing something?
  16. #14
    Aug 2002
    SW Missouri
    2,438
    Quote Originally Posted by Opelmel View Post
    There are only three.
    TMK
  17. #15
    Oct 2002
    The Villages, FL
    4,801
    Quote Originally Posted by tomking View Post
    Told you I'd screw something up. I was thinking 4 wheels and the one at the diff. except for the fact that the one at the diff. takes care of the 2 rear wheels so I stand corrected and accept all flogging as legitimate.
    www.markandson.net
    www.gpny.com
  18. #16
    Aug 2002
    SW Missouri
    2,438
    Jeff you are distracted by all this water pumping!:banghead:
    TMK
  19. #17
    Jul 2005
    Omro, WI
    1,395
    Mel
    Sorry, but I'm not into flogging. I get enough pain to satisfy any sado-masochistic tendencies simply by working on Opels.
  20. #18
    Sep 2003
    New Roads, LA
    66
    Brian Pangburn
    Thanks everyone!
