I'm not sure, but I think my restored opel's back brakes need some adjustments ...
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 14 of 14
Thread: I'm not sure, but I think my restored opel's back brakes need some adjustments ...
    Feb 2010
    TX
    103
    Yes, this is my first opel ... and I may not know how the brakes should look, but I think I have a issue ... or two. See pics
    Member guyopel's Avatar
    Feb 2003
    Duluth,Ga.
    1,447
    John
    You need to replace both wheel cylinders and replace rear drums .HTH
    John
    Guyopel
    ---Thomas Edison
    Feb 2010
    TX
    103
    The interesting part was that the wheel cylinders are so messed up that they do not leak fluid.
    Feb 2010
    TX
    103
    I'm guessing that the drum will be hard to find locally and that there is no easy replacement. I guess I'll be internet shopping.
  7. #5
    New/Old Owner 1973 GT JimVonBaden's Avatar
    Dec 2009
    Vienna, VA
    860
    Jim
    Amazing! My 20 year sitting "Barn Find" is in much better shape than that!
    Jim
  8. #6
    Sep 2007
    Western Mass
    64
    Hey, at least the shoes are good. Get a little crazy with the BFH on that drum? They can be hard to remove sometimes. Next time try striking on the face with a dead blow or heavy rubber mallet. If it were me I would fill the chipped areas with weld and take it down to the local Napa where they would put it on the lathe and make it good as new. The drum looks like it "was" in pretty good shape.
  9. #7
    UFOpel Investigator Site Supporter Aardvaark (R.I.P.)'s Avatar
    Aug 2007
    Des Moines, Iowa
    3,472
    Mark
    I wonder what surprises await his other "restored" Opel buyers.
    He must have meant that the cars were stored somewhere, removed from storage and
    then put back in storage again. Before he put them on fleebay. You just miss understood what he
    meant in his auction description by "re-stored".
    -Mark
    '75 Manta
    Having invested my life savings into
    this Opel Manta. I expect big returns.😅
    Link to my album of Opel catalogs
    and magazine articles:
    https://www.opelgt.com/photopost/show...ser/23031/sl/a
  10. #8
    Sep 2007
    Western Mass
    64
    Thumbs up
    Quote Originally Posted by Aardvaark View Post
    Now that is a good one. This baby sure does look to have been "re-stored" more than once.
    My Condolences to the O.P. However, I will say I admire your tenacity. Just keep at it and you will get it sorted out eventually.
  11. #9
    Feb 2010
    TX
    103
    The drum was already tweecked before I got to it ... I was assuming that the factory used weight reduction to lowered the wheel inertia and helped the car go faster and save gas ...
  12. #10
    Apr 2006
    Michigan
    135
    Bleed those rear brake lines completely multiple times to remove all crud before you connect them to the new brake wheel cylinders.
    After looking at your photos, I suggest you drain and replace all the fluids on that car including the rear axle, transmission, engine oil and coolent, and brake fluid. Also clean and repack your front wheel bearings. Opel GT's are fun to drive on the freeway and you will want all those lubricants fresh.
    You may need to have your fuel tank inspected and cleaned to remove crud and rust given it looks like this car was not driven for a long time.
  13. #11
    Spofford, NH
    13,059
    Bob Legere
    Looks like a typical car that never had the brake fluid changed in its' lifetime.:banghead:
  14. #12
    No....its not a Buick.... yellaopelgt's Avatar
    Feb 2005
    On Wind Lake WI.
    1,523
    Joe
    I'd go one step further and suggest just to just go ahead and replace all the rubber brake hose's as well if they look as bad as the rest of the system. Probly easier to do it in one shot anyway. Bet your bottom dollar one of them is collapsed...
  15. #13
    Aug 2007
    Des Moines, Iowa
    3,472
    Mark
    Sure is the worst one I've ever seen.
    -Mark
    '75 Manta
  16. #14
    Detritus Maximus opelbits's Avatar
    Jul 2002
    St. Louis MO
    1,996
    I would say go here:
    http://www.rockauto.com/catalog/x,make,OPEL,vtype,US
    You may have to search the Manta listings to find all the parts. For some reason, even though the parts are the same, Rock Auto is not consistent in their listings. Drums and wheel cylinders are listed for the Manta, but no drums for the GT, but it's the same part. Also, when you see several different suppliers listed for a part, don't automatically assume the cheapest will cost less. They have several warehouses and the cheapest part may be in the warehouse farthest from you. You could save $5 on the part but pay twice as much in shipping.
    A pair of drums (Centric brand) comes to about $160 total with shipping. The wheels cylinders were $14.90 each (Dorman) and $38 total with shipping for two. The 74 Manta listing shows the Centric wheel cylinders ($12 each) and the 71 GT does not.
    I prefer going to OGTS, but if price is a priority and you have the patience to sort thru listings and shipping, Rockauto can be very helpful.
    "No, it's not fiberglass."
    1. Back brakes not working either
      By rskdsk in forum Group 5 - Brakes
      Last Post: 02-23-2010, 10:50 PM
    2. Headlight bucket adjustments
      By sawdust in forum 2C - GT Headlamps Troubleshooting, Removal and Repair
      Last Post: 05-06-2008, 12:07 AM
    3. Rolled back odometer on restored GT
      By arihillfarmqh in forum General Discussions
      Last Post: 07-25-2006, 02:42 PM
    4. solex adjustments.........
      By greensmurf20 in forum Solex Carb Repairs
      Last Post: 02-11-2005, 09:21 AM
