Best Long Term Engine Storage Ideas?
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 16 of 16
Like Tree30Likes
  • 1 Post By The Scifi Guy
  • 1 Post By rrossjr
  • 1 Post By dpre
  • 2 Post By
  • 3 Post By kwschumm
  • 2 Post By soybean
  • 1 Post By kwschumm
  • 2 Post By The Scifi Guy
  • 2 Post By kwschumm
  • 2 Post By norbertone.gt371
  • 2 Post By First opel 1981
  • 3 Post By Knorm65
  • 2 Post By dpre
  • 3 Post By opelspyder
  • 2 Post By Manta Rallier
Thread: Best Long Term Engine Storage Ideas?
    Nov 2007
    Cöllingswööd, NJ
    13,681
    Gördö
    6
    I'm planning on rebuilding my previous engine and I'm thinking that instead of selling it I might just sit on it long term.
    What would be the best way to store a freshly rebuilt engine for a couple of years or more?
    Should I put it together and gasket it all up, maybe spray the outside with a sealer, pour in some oil, some in the cylinders, wrap in a plastic bag, etc., etc.?
    Or should I leave it as separate block and head(and maybe remove cam/valve stuff), oil pan removed, and everything hosed down with preservative, then wrapped in plastic bags. By preservative I mean this stuff I can get from work, kinda like cosmoline, that's for sealing guns and machinery long term that leaves an oily wax-like coating that stops rust.
    Wide ranging subject, talk about anything you want.
    dpre likes this.
    Hoosier Opeler Site Supporter rrossjr's Avatar
    Mar 2004
    Central Florida
    2,372
    maybe spray the outside with a sealer...
    Engine fogging spray
    soybean likes this.
    RunOpel dpre's Avatar
    Mar 2019
    Port Orchard, WA
    715
    Dan
    Great timing Gordo I'm in the process of rebuilding a 1.9 I just pulled from a 1970 Opel GT. Still undecided whether I should keep it at a 1.9 or go with a 2.0 (I know a lot of you would say go 2.4 getrig...problem is cost )
    My goal is to eventually replace with my original 1.9 in my 1971 Opel GT which has 122,000 original miles and still performing awesome.
    So this is great timing for me. I look forward to hearing a lot of different opinions. I'm sure this topic will generate as many or more comments as the shifting topic did
    I hope Bob, Keith and Charles will chime in as well as many others. If I remember reading past posts about this topic, most felt completing the rebuild with added oil and wrapping in plastic. I wondered after you have stored the engine in whatever process is appropriate, do you ever go back and re-oil or have to do anything to keep the engine preserved.
    Dan
    soybean likes this.
    Nov 2007
    Cöllingswööd, NJ
    13,681
    Gördö
    6
    Here's another one I found when viewing Ron's link:
    https://www.amazon.com/dp/B000XBKG0A...NsaWNrPXRydWU=
    soybean likes this.
    Feb 2018
    Finland
    483
    Squirt oil in the cylinders and close all holes where debris or dust can enter in the engine, cover it, but not too hermetically so you still can turn the crank every now and then to keep the piston rings from seizing if the oil for some reason isn't doing its job.
    soybean and dpre like this.
    Nov 2009
    Pacific NW
    1,956
    Ken
    Quote Originally Posted by Commodåren View Post
    Squirt oil in the cylinders and close are holes where debris or dust can enter in the engine, cover it, but not too hermetically so you still can turn the crank every now and then to keep the piston rings from seizing if the oil for some reason isn't doing its job.
    Don't forget that humidity in air condenses into water and causes rust. It's best to store the engine in an area where temperature is kept above dew point. I've found that a master bedroom closet works well
    soybean, The Scifi Guy and dpre like this.
    Nov 2002
    Reidsville N.C.
    2,894
    W Jarrell Young
    Quote Originally Posted by kwschumm View Post
    Or add a dehumidifier? to the above suggestions. Jarrell
    tealcarver and dpre like this.
    Nov 2009
    Pacific NW
    1,956
    Ken
    Doesn't even need to be that fancy really. Make a wood box out of rigid foam insulation and put the engine in it with a small heater of some kind. A block warmer, or light bulb, or something that generates heat. Just be sure to keep the heater away from anything flammable inside the box. Or you could even install a block heater and leave it plugged in.
    dpre likes this.
    Nov 2007
    Cöllingswööd, NJ
    13,681
    Gördö
    6
    Holy Cow! You guys in the Northwest really DO smoke better weed than we do!
    kwschumm and dpre like this.
    Nov 2009
    Pacific NW
    1,956
    Ken
    I'm just really tired of anything metal rusting in a dry shop. Can't wait for my new heated shop to be done!
    Dec 2009
    Germany/Bremen
    4,231
    Norbert
    Take old oil and for the cylinder rooms a weapon oil like Ballistol.
    All 6 to 8 week turn the engine that the piston rings get a other position.
    Schöne Grüße an alle Flachkadetten!
    Apr 2003
    Portland, Oregon
    8,713
    Here's what I did.
    I sprayed a diluted mixture of oil and 99% isopropyl inside the guts. I torqued the rods down as well as the mains using 90W as a lube. I put some dessicant packs in the pan and cylinders.
    Then I put everything together but didn't torque anything down.
    I relaxed all the springs on the rockers. Added another set of dessicant packs under the valve cover.
    It was already on an engine stand so I covered it with a plastic bag and zip tied the bag at the engine stand shaft.
    It's a good idea to leave a note for yourself inside, just to remind yourself where you left things.
    Can Opeler Knorm65's Avatar
    May 2014
    Norman, Oklahoma
    3,146
    Kyler Norman
    5
    I just have mine on a stand in the corner. I turn the engine over by hand every month or so when I’m bored. It’s still nicely coated with old oil.
    "Kara," 1972 Opel GT Targa, Welded Doors, Rhinolined, 40 DCOE SSD, Working GM AC
    Mar 2019
    Port Orchard, WA
    715
    Dan
    Gordo up here in the northwest, if you stand in one place to long, you will collect moss and rust
    Not sure if our weed is any better, never tried it, but we do have our share of weeds
    Dan
    Opel Key Master opelspyder's Avatar
    Tennessee
    4,804
    Keith Lundholm
    4
    If you leave it in pieces, then coat with grease for long storage, yes, you will have to clean it thoroughly but it wont rust. If its all together, and fresh, put oil in it and prime the oil system so it at least has oil throughout. They do make spark plugs that have desiccant in them that you could use, maybe put in an insulated crate. Just depends on how long you anticipate it to sit I guess
    www.newvintageauto.com
    Opel Rallier since 1977
    Aug 2006
    Afton VA
    891
    There are preservative oils used in long term storage of aviation piston engines that you might want to look into. The cylinders seem to be the most likely part to rust... I can't recall opening any engine from long term storage or sitting in a j-yard, with rust on the cam lobes, unless it was left open to rain with the breather open or similar where it actually got water directly into the engine. And relaxing the load on the valves springs as suggested is a good idea.
    And FWIW.... the engine I am working on sat for 5 years or so in the car. Had a minor head gasket leak letting coolant into #2 and #3. #3 has an area of light rust on part of the cylinder wall of about 1.5-2 sq inches.... enough that you can feel it. Compression test was 130-135 psi before ever starting it. So not as bad as I mighta thought think.
    FWIW #2: I have broken a ring on an engine trying to turn it over that got lots of rust inside. It was on the ground under a sheet of plastic.
