72 1900 wagon auto to manual conversion
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 14 of 14
Like Tree18Likes
  • 2 Post By 73Manta72gt
  • 2 Post By The Scifi Guy
  • 3 Post By RallyBob
  • 1 Post By 73Manta72gt
  • 1 Post By BQS4
  • 1 Post By The Scifi Guy
  • 3 Post By Timbo
Thread: 72 1900 wagon auto to manual conversion
    Member 73Manta72gt's Avatar
    Nov 2002
    Winston-Salem, NC
    460
    19
    hi all, I need some help in the shifter area. The auto shifter installs with 4 screws in a square hole. How is the manual car setup?? What holds the rubber shift boot in place. Any pictures would be helpful. diameter of hole in floor? I thought a metal ring might hold the boot in place.
    Thanks in advance
    Ooooner and soybean like this.
    Nov 2007
    Cöllingswööd, NJ
    12,581
    Gördö
    6
    Square boot I presume. This is a pic of a '70 Kadett shifter:
    Spofford, NH
    12,911
    Bob Legere
    Quote Originally Posted by 73Manta72gt View Post
    Thanks in advance
    The auto version has a raised sheet metal framework for the auto shifter. This needs to be removed.
    The manual shifter boot is round, retained in a rectangular sheet metal frame with a round hole with a raised lip to hold the boot.
    Ooooner, soybean and The Scifi Guy like this.
    '70 GT 'Bonnie', '71 Ascona 4-dr turbo - winter beater, '71 Ascona 4-dr 'Turd' - rallycar, '72 Manta Rallye - hillclimb car, '72 Ascona wagon - 'Red', '72 Manta - caged street car, '73 Manta Luxus, '73 Ascona 2-dr, '74 Ascona 2-dr - Project X, '74 Manta Luxus - factory sunroof, '74 Manta ITB racecar, '75 Manta, '75 Manta - racecar
    Nov 2002
    Winston-Salem, NC
    460
    19
    Thanks guys, I'll post some picture with the area mark where I think I should cut
    Ooooner likes this.
  7. #5
    Southern Red Neck BQS4's Avatar
    Snellville, GA
    9,556
    Gene
    Thanks guays, I'll post some picture with the area mark where I think I should cut
    I did this with my Wagon, you need that piece off the firewall where the clutch cable comes through, this can be bolted or welded on, but, it is a key piece
    tomking likes this.
  8. #6
    Nov 2002
    Winston-Salem, NC
    460
    19
    I started cutting out sheet metal parts for the firewall and I think I'm ok on that area
  9. #7
    Nov 2002
    Winston-Salem, NC
    460
    19
    So I just need cut out the area that isn't flat and add sheet metal patch with a hole for the shifter boot..like in attached?
    soybean likes this.
  10. #8
    Spofford, NH
    12,911
    Bob Legere
    The raised automatic adapter is spot welded in place as I recall. I’d simply remove it to expose the original 4-speed hole, rather than cut it out oversized.
  11. #9
    Nov 2002
    Winston-Salem, NC
    460
    19
    Thanks, now I have a new problem hood won't release. when I pull the hood release cable I can feel it pull against the spring but hood won't release. Any suggestions I'm just about ready to cut a hole in the hood
  12. #10
    Nov 2007
    Cöllingswööd, NJ
    12,581
    Gördö
    6
    I guess your wagon is more or less the same as mine and the Manta parts car I got. Those hood latches appear to be big trouble waiting to happen.
    I'm told that one thing to make sure of it that the cable housing isn't moving when you pull on the cable. I noticed that the cable housing on the car I'm stripping has a pot metal end about 2"-3" long near the cable handle and it's damaged and the cable housing is pulling through. I'm also told that people think they've pulled the cable enough and tried to open the hood, but it's not quite fully unlatched and they yank on the hood and this causes the crossmember that holds the latch catch to pull away from the hood and get bent, as it is on my yellow wagon. So, make sure your housing is staying anchored.
    I've heard that you can drill a hole somewhere in the lever that disengages the latch and you can then install a loop of cable there that you can pull on if the T-handle won't unlatch the hood.
    Once you get the hood open again, I would suggest doing everything you can think of to loosen up that hood latching mechanism and lube the heck out of it.
    soybean likes this.
  13. #11
    Senior Member Timbo's Avatar
    Feb 2012
    Auburn, NH
    676
    Tim
    Have you tried pushing down on the hood while you pull the release? Sometimes, taking the load off the release latch will allow it to move and release.
    Gary, soybean and The Scifi Guy like this.
  14. #12
    Nov 2002
    Winston-Salem, NC
    460
    19
    I will try that tonight and see if it helps.
    soybean likes this.
  15. #13
    Nov 2002
    Winston-Salem, NC
    460
    19
    The good news and bad news... Good news: Because the car was on run up block I had enough room to lay under it and reach my arm up and move the latch. I added a second cable just in case this happens again. Bad news: The car has been sitting with the transmission out for about 6 weeks and the interior has suffered a lot of poop damage from wrens going in and out the hole for the shifter. I found one dead in the car from heat stroke.
    soybean likes this.
  16. #14
    1000 Post Club soybean's Avatar
    Nov 2002
    Reidsville N.C.
    1,979
    W Jarrell Young
    Helmet, don't you have bird boxes for your Wrens? Don't you know you're not supposed to leave pets in the car on hot Days? Good luck my friend, Jarrell
    1. rear brake noise ..anyone have drums for 72 1900 wagon?
      By stevyz in forum Group 5 - Brakes
      Last Post: 11-03-2012, 07:59 AM
    2. limited choices : will a '80+ opel record manual box mount to the manta 1900 motor?
      By timothy lagden in forum Clutch, Transmission and Drive-train Upgrades
      Last Post: 05-29-2010, 12:06 PM
    3. Solex Auto to Manual choke conversion?
      By 2 Fast 4 U in forum Solex Carb Repairs
      Last Post: 01-15-2006, 11:54 AM
    4. Conversion From Auto to Manual
      By pamgroove in forum 7B Transmission
      Last Post: 10-07-2005, 08:38 PM
