5-speed gearbox and LSD in ASCONA B 1.2S
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
Thread: 5-speed gearbox and LSD in ASCONA B 1.2S
    Opeler ASCONA-HOLIC's Avatar
    Mar 2008
    Greece
    29
    Hallo after a very long time I was away. I want to have a piece of information on the subject of this thread. Can we put a 5-speed gearbox and a limited slip defferential on an ASCONA B 1.2? I know that there is LSD for this engine, what about the gearbox? I know that probably there is not much utility in this, but I just want to know what can we do on it. Which 5-speed gearbox and how can we combine it with the 1.2 CIH engine?
    Opeler blind_msq's Avatar
    Nov 2008
    Romania
    87
    You can get a gearbox from a manta B (perfect fit) or from a rekord E, but i think you might have to modify the cardan as well.
    As for the lsd... only heard of it's existance, but never saw one. Crossed my mind to get one for my rekord c.
    Rekord C owner. Driver...someday.
    My cars on Flickr
    boomerang opeler baz's Avatar
    Jun 2002
    sunderland england
    5,617
    barry williams
    what are the ratios in the 1.2 box ? do they match the 2l box from 1 to 4 if not it will be a pain to get going and clutch life will suffer you may be better off with a slightly higher diff and keep the 4 speed box
    lsd's can be bought from quaife but dont know if the half shafts from a 1.2 will match the splines in there diffs you may need to change to a set from a larger engine ascona to fit
    Differentials - Quaife Engineering
    An Eagle may fly high but a Weasel doesnt get sucked into a jet engine.
    Your Noble Friend ;-) G.v.Mainberg's Avatar
    Nov 2004
    Atlanta, GA - USA
    3,882
    Quote Originally Posted by blind_msq View Post
    Be careful - the 5-speeds from Manta/Rekord are all made to fit the 1.9-2.4 Liter CIH engines. Your 1.2 Liter needs a completely different bell housing, and I would not know of any 5-speed that is a direct bolt-on.
    As for the LSD, the answer is kinda similar. The known LSDs all fit the "large" axle frame for the CIH engines. If you want 5-speed and LSD, take a complete drive train including engine from a CIH Manta/Ascona. Changing out everything (including front axle, brakes and MBC/booster) will be a direct and cheap bolt-on for you!
    Dieter
  7. #5
    Calgary, Alberta, Canada
    5,556
    5
    Quote Originally Posted by ASCONA-HOLIC View Post
    I presume you mean a 1.2 OHV engine, as I have never heard of a 1.2 CIH. AFAIK, the CIH came in the following displacements: 1.5, 1.6, 1.7, 1.9, 2.0, 2.2 and 2.4. But not a 1.2, which means that that you cannot use a CIH-compatible transmission
    Finishing up a bare-metal, nut & bolt rotisserie restoration of my '71 Opel GT
  8. #6
    Nov 2008
    Romania
    87
    Might not be important but the 1.2 ohv was also mounted on the kadett c.
    A friend of mine owns a kadett C coupe with an 1.2 "tuned up" engine. Noisy and powerless baby monster.
    My cars on Flickr
  9. #7
    Mar 2008
    Greece
    29
    Yes, correct I mean 1.2 OHV engine, sorry for my mistake. Concerning the LSD I already know that there is a compatible one for this engine. For the 5-speed gearbox however I have never seen anything on this engine and I am just into getting some information. Thank you all for the replies. If you have any other information I would like to know.
  10. #8
    Detroit,where my home was 2 Fast 4 U's Avatar
    Oct 2005
    Netherlands
    2,860
    Erick Janssen
    To my knowledge there is no 5 speed transmission to fit the 1.2, at least not for a rear wheel drive car.
    Opel Ascona;
    Only built from 1970 - 1975
    Understeer: The front of the car hits the wall,
    Oversteer: The rear of the car hits the wall,
    Horsepower: How fast the car hits the wall,
    Torque: How far the car pushes the wall.
