75 manta build - Page 5
Thanks Thanks: 0
Likes Likes: 0
Dislikes Dislikes: 0
Page 5 of 5 FirstFirst 12345
Results 81 to 96 of 96
Like Tree48Likes
Thread: 75 manta build
  1. #81
    Dec 2016
    mt vernon, wa
    216
    The project is still alive. I was not able to work on it for about 7 month but am now in a new place with a garage. I have pulled the motor out to do a rear main seal and a few other things, while it is out I have been working on the engine bay and front suspension. I cut out the old rusty battery tray area and replaced it with fresh metal but I boxed it in so there is a consistent shelf across the fire wall( battery is in the trunk). I also removed the heater and welded that hole shut.
    soybean likes this.
    1962 olds f85 cutlass: 455, 4l80e
    http://classicoldsmobile.com/forums/...5-cutlass.html
    1975 opel manta: 215, t50
    https://www.opelgt.com/forums/member...nta-build.html
    Looking for borg Warner t50s (trannys/parts/rebuild kits)
  3. #82
    Dec 2016
    mt vernon, wa
    216
    Here are some pictures.
  4. #83
    Dec 2016
    mt vernon, wa
    216
    I was able to get some assembly done after finishing the welding for the shock relocation. Sorry for the sideways pictures.
    saxybiker and soybean like this.
  6. #84
    Dec 2016
    mt vernon, wa
    216
    Engine is ready to go back in.
    soybean and Mercougary like this.
  7. #85
    Nov 2002
    Reidsville N.C.
    2,310
    W Jarrell Young
    I haven't been online since you started this thread, so I need to start from the beginning to this last post. From what I have seen, you have put some good work into this car. The only thing, I might question, which Rallye Bob might chime in on, is the header wrapping. I did the very same thing to my 78 Chevy 454 Dually, built to pull a 15,000 lbs Grain trailer. The Wrap does cut down on the heat in the engine bay, but when driven through water, will soak it (water) up, resulting in the headers rotting prematurely due to the wrapping. Others who have done this might have had better results than I did, but this is just what happened to me. Sincerely, Jarrell
  8. #86
    Dec 2016
    mt vernon, wa
    216
    Engine is in, tranny tunnel complete and floor painted. https://grassrootsmotorsports.com/fo...2/#post2725817 Pictures here
  9. #87
    Nov 2002
    Reidsville N.C.
    2,310
    W Jarrell Young
    The pictures look awesome, you will have a beast when you get done. What kind of shock are you planning on useing to keep the weight off the front end? I still need to start at the beginning and read your whole thread. Thanks, Jarrell
  10. #88
    Dec 2016
    mt vernon, wa
    216
    It has bilstein shock all around.
  11. #89
    Dec 2016
    mt vernon, wa
    216
    Car is running and together enough to do a short ride. Still need to do little things here and there to square it up.
    soybean likes this.
  12. #90
    Dec 2016
    mt vernon, wa
    216
    The car has had a couple of short drives now. Still not a hop in and drive car but getting there.
    soybean likes this.
  13. #91
    Dec 2016
    mt vernon, wa
    216
    Well, she made it through the last two years of being off the road. I have the engine where I am happy, I need to through my panhard bar back on and a few other small things but she will soon be a car I can hop in and drive any time. https://www.youtube.com/watch?v=e0rA...ature=youtu.be
  14. #92
    Dec 2016
    mt vernon, wa
    216
    My rear end blew up after about 25miles with the new engine. Looking to put a stock axle back in so I can drive the rest of the summer then do a swap to a stronger rear this winter.
  15. #93
    Dec 2016
    mt vernon, wa
    216
    I was able to pick up a rear diff from mercugary Sunday, put the parts in my car Monday and now I have a driver again.
    Mercougary likes this.
  16. #94
    Opeler Opel-In-The-Rough's Avatar
    May 2019
    SoCal The OC
    25
    AJ
    Quote Originally Posted by young olds View Post
    Strong work!💪
  17. #95
    Opel Rallier since 1977
    Aug 2006
    Afton VA
    456
    I always wanted to put a 215 in SOMETHING LOL
  18. #96
    Dec 2016
    mt vernon, wa
    216
    Dropped a valve about a month ago, I have a 63 cutlass sitting in the driveway with a running donor engine. Need time to do the swap. Doing rear suspension work currently as well.
    1. 74 Manta build
      By Rally Manta in forum Racers Forum
      Last Post: 03-08-2018, 03:36 AM
    2. V8 Manta SCCA build
      By ohiocymru in forum Engine Swap Forum
      Last Post: 04-05-2016, 09:54 AM
    3. V8 Manta SCCA build
      By ohiocymru in forum Mechanical
    4. Starting the build For the coolest Manta I have ever seen!
      By Boedy in forum General Discussions
      Last Post: 04-28-2011, 03:45 PM
    5. Kopps 1974 Manta build
      By BennyTheKopp in forum Manta
      Last Post: 03-05-2010, 05:46 PM
