Manta/Ascona Pertronix Simple-Hookup Switched-12V Source.
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By dcm013
Thread: Manta/Ascona Pertronix Simple-Hookup Switched-12V Source.
    Cunning Linguist Site Supporter tekenaar's Avatar
    Plano, TX 75074-3440
    5,292
    Otto
    LightbulbManta/Ascona Pertronix Simple-Hookup Switched-12V Source.
    Been using this for several years now, so I thought I'd share. It's simple, direct and doesn't require additional long wire runs. Another plus is that it can be made very stealthy, i.e. "stock looking", without much effort. Here's the trick . . .
    . . . get a male and mating female 'bullet' connector, cut the eye connector off the Pertronix red wire lead and strip enough off the end for either bullet connector, insert and crimp. Then, just strip a bit of the insulation off the horn's switched 12V wire, (LILAC), about 1/2" should do it, double it over and insert into the remaining bullet connector and crimp. Insert the male bullet connector into its female counterpart and you're done . . . like this below . . .
    Opeler dcm013's Avatar
    Aug 2002
    Troy, MI
    746
    Don McLean
    Or you can go to Radio Shack and buy a pack of connectors that include single female to double male spade connectors so you can use the existing horn wire/connector and replace the ring connector on the Pertronix with a female spade. Then the original horn wire is left unmolested.
    wrench459 (R.I.P.) likes this.
    Oct 2005
    Acworth, GA
    3,088
    juan P. Blanco PH.D.
    This method is interesting however I would not do it.
    The Pertronix is made to hook up to a coil +/- terminals, as the instructions tells you. And though a power supply is a power supply, the horn has about 14V when the engine is running and the coil does not. You also lose the benefit of the resistor wire and most all, it just looks like a botched up job which is very far from being stealthy.
    The best method is to follow the instructions on the box.
    www.edcatl.com
    Home of the S-ECU
    5,292
    Otto
    QuestionInteresting, Juan . . .
    Quote Originally Posted by blancojp View Post
    . . . I haven't bought any Opels recently and haven't installed a new Pertronix unit lately. Whereas Pertronix used to tell you to hook their unit's red wire directly to a switched +12V source, not the coil's + side, evidently their instructions have changed.
    I would submit to you that the Pertronix red wire should be connected directly to a switched +12V source when converting a stock, resistor-wire coil Opel ignition system however. The coil + side sees the full +12V only during start and ~+9V with the engine running, which is my point . . . unit is designed for running on +12V (in reality 14+V when engine is running!)
    That said, however, I've been running my '75 Ascona's unit exactly as described in my first post for about 10 years now . . . never any hint of a problem. All of my Pertronix units have been wired like this since 1978, when they were Perlux!
  7. #5
    Oct 2005
    Acworth, GA
    3,088
    Perhaps this would share some light.....
    http://www.pertronix.com/support/man...itor12vneg.pdf
    www.edcatl.com
    Home of the S-ECU
  8. #6
    Tennessean Site Supporter hrcollinsjr's Avatar
    Jan 2003
    Chapel Hill, TN
    8,135
    Harold Collins
    Some Pertronix Specs
    Pertronix Specifications
    •Operating Voltage: 8-V to 16-V DC
    •Temperature Range: -50 to 300F
    •RPM Range: 0 to 15,000 RPM
    •12-V NEG Ground (some 6-V NEG, 6 & 12-V POS ground kits available)
    P.S. For those that like to 'toot' their own horns, I wonder how much voltage drops when using the horn?
  9. #7
    7,000 Post Club wrench459 (R.I.P.)'s Avatar
    Jul 2005
    Milner, GA.
    11,747
    Dan
    12
    Toot Toot this sounds like fun.
    Current draw 02 durango horn.
  10. #8
    Spofford, NH
    13,136
    Bob Legere
    My air horn in my car draws 18 amps!
  11. #9
    Jul 2003
    San Diego, CA
    2,828
    Low Voltage Problem
    Q. How to correct a low voltage problem?
    A. First, if you have an external ballast resistor, connect the red Ignitor™ wire to the ignition wire prior to the ballast resistor.
    B. Second, if you do not have a ballast resistor you must locate a 12 volt source that is controlled by the ignition switch to connect the red Ignitor™ wire to.
  12. #10
    Jul 2005
    Milner, GA.
    11,747
    Dan
    12
    Opel horn waveforms
    First off only one horn was working tonight and the battery voltage was low.
    One horn current ramp.
    The voltage drop on the postive side. Scope is set the same as Otto's setup.
    HC I told you that is was a little dirty.
    And as a bonus... battery charger waveform.
  13. #11
    Opel Key Master opelspyder's Avatar
    Tennessee
    4,792
    Keith Lundholm
    4
    Even when running the 12v wire to the Pertronix...it has the potential for 14v...like all the 12v system, which actually is designed to withstand 16v, bulbs and all. While they do run off the resistance wire...many members have had issues running theirs with the resistance...so 12v source fixed there problem. Otto's way is the same as running a separate wire...but I don't like splicing into wires like that either.
    www.newvintageauto.com
  14. #12
    Member opeljohn's Avatar
    Sep 2003
    Springfield IL
    1,631
    What number fuse off the fuse block would be best in the 75 1900/Ascona. I have a stock coil with the red wire for my petronix running from it right now. Seems to run okay but maybe could be better. May try Ottos way but what the heck I have plenty of red wire.
    1. Manta front jack point source?
      By Gordy in forum Manta
      Last Post: 04-26-2012, 08:52 PM
    2. Ascona Windshield source?
      By oldopelguy in forum General Discussions
      Last Post: 03-22-2010, 06:50 PM
    3. Simple question
      By Rebel Ed in forum Introductions
      Last Post: 10-03-2006, 08:42 PM
    4. Solex vacuum line hookup
      By Dan-MI in forum Solex Carb Repairs
      Last Post: 04-23-2006, 11:52 AM
    5. Compressor hookup for calipers
      By Jeff Pozorski in forum Group 5 - Brakes
      Last Post: 06-10-2003, 12:51 PM
