1 - 8 of 8 Posts
Manta Maniac
Thought I'd post a couple of pics to let you see what the euro spec 1.2 looked like in the Manta....pretty sad really......
PrOpeller
Awe, that doesn't look bad. Wonder how it handles and what fuel mileage it has? I think Charles was looking for one of these Mantas, btw. Thanks for the pics.
these are figures for the vauxhall viva which is a kadett in "ha" but after it is a new model completely but power for the 1.2's are close to a low comp 1.9
* Body Styles
Saloon (2 & 4 door), Estate, Coupe
* Amount made
Around 600,000
* Engine sizes (Early)
1159cc (70.7 cu in)
1599cc (97.5 cu in)
1975cc (120.4 cu in)
* Engine sizes (Later)
1256cc (76.6 cu in)
1797cc (110 cu in)
2279cc (139 cu in)
* Weight
1790 to 2220 lbs (812 to 1007kg)
* Length
13 feet 7 inches(4.138 metres)
* Top speed
79 - 119 mph
* Fuel economy
21 - 29 mpg
* Price then
£700 - £2500
* Trim levels
Basic (1159, 1256, 1599, 1800cc) 1256 had about 65 bhp
Deluxe (1159, 1256, 1599, 1800cc)
SL (1159, 1256, 1800, 2300cc)
Viva E (saloon & coupe) 1256cc
Viva GLS (1256, 1800cc)
Magnum sal/coupe (1800, 2300cc)
Firenza (1159, 1256, 1800, 2300cc) ( 2.3 had 131 bhp and went like the wind)
Sports hatch (2300cc)
Also, the Estate version was available with most trim
Opel Tinkerer and Rescuer
YEs actually I was thinking of bringing over a 1.2L if I could find one in Europe not in need of a lot of work. Just to be different.
Was the rear end and other parts smaller, like they did on the GT, or just the engine?
Charles
Vendor
Looks like they made the windshield washer reservoir bigger... :D
(doesn't it look huge in that engine compartment?)
TK
A 1.2 in a 1.1 car makes a BIG difference.
Had a 1979 Ascona 1.2 engine put into a 69 Kadett once.
105-110 top speed requires full lane width to handle.
Gas mileage was around 25-28....
we didn't get these in mantas here, but they came in the Kadett C, and they weren't bad at all, much faster than any italian 1.3 engines of the time.
Bigger is Better!
The 1.1L is 1078cc with a 75mm bore so it is posible to bore it to 78mm to get 1.2L at 1159cc. Might be pushing it a bit to fit 1.3 (1256cc) pistons at 81mm bore size ....... All of the motors have the same stroke at 61mm - 2.40" so the pin heights will probably be the same .....
So OldOpelGuy - will those 11SR blocks punch out 6mm ????
1 - 8 of 8 Posts
