A 1,9 liter engine makes around 47 hp/liter, a 1,5 liter one makes around 43 hp/liter, so no, I don't think a 15S cam is hotter than a 19S one.
Hmmm, I looked at my list and noticed the 1.5S isn’t listed, so I’m not sure.Was the cam in a 1.5 different from the stock 1.9 cam? I'm still trying to sort out "The Beast" and a found a cryptic note in the seller's pile of paperwork that said "street performance camshaft from Opel 1.5 litre engine = higher lobe lift and greater duration". Any info would be appreciated.
The CIH cams are easiest to identify by a stamped letter at the rear end of the cam. K=20S
R=20E
M=22E
U=C24NE
C=19E
D=19SH
A=19S,17S.
B=19US (hydraulic)
Is it on the very end (the round "butt" end, or on the surface of the cam itself? I'll see what I can see.Hmmm, I looked at my list and noticed the 1.5S isn’t listed, so I’m not sure.
Can you see the letter stamped on the rear of the cam by any chance? If it’s a ‘A’ then it’s no different than the normal 1.9solid lifter cam.
Bob said the End of the camshaft. HTHIs it on the very end (the round "butt" end, or on the surface of the cam itself? I'll see what I can see.
He said "rear", which could have meant the end (as in his subsequent pictures) or on the rear of the cam (as in FO81's pictures).Bob said the End of the camshaft. HTH
Thanks Bob. That clears it up for me. I'll see if I can get a look at it, but I have my doubts.Here’s the end of a stock US-spec 1.9 hydraulic cam. View attachment 457334 View attachment 457335
Here's are pics of the end. No letter stamped on it that I can see.Hmmm, I looked at my list and noticed the 1.5S isn’t listed, so I’m not sure.
I didn't see any at all. Must be a super-secret "stealth" cam.There will be numbers cast into the shaft. Can you get to those to see what they are?
Hard to see with the cam in the head. They're there.I didn't see any at all. Must be a super-secret "stealth" cam.
No matter how I go at it, I can't find any numbers. If they are there, pulling the cam would probably be the only way to see them - and I'm not willing to do that - yet!Hard to see with the cam in the head. They're there.
That's the only way to see them. Pulling the cam is easy. Resetting the valves isn't that hard either.No matter how I go at it, I can't find any numbers. If they are there, pulling the cam would probably be the only way to see them - and I'm not willing to do that - yet!
