41 - 43 of 43 Posts
Cam timing would be the same with no change (crankshaft gear is held in place by the timing chain) what has move is the distributor timing .
Remove the fuel pump then the distributor and reinstall it in correct position after you reinstall the lower gear drive and front pulley.HTH
Timing Marks
I was always told that the beautiful raised timing marks on the later model covers were useless. "Have to look at the flywheel ball and pointer thru the window." This sure looks like a factory notch in this pulley. Is this TDC? It's orientation seems to be correct with the keyway vertical.
41 - 43 of 43 Posts
