I've been toying with the idea of turbocharging the GT since the day I got it. Just something about the car only having 70 hp just doesn't fit well with its sporty appearance. Initially I plan on pushing 175- 200 hp, this would make the car alot of fun to drive. Then crank it up and see if I can hit that 300 hp mark.
Any way, the past couple days I've been taking some measurements to find the best position to mount the turbo, so far it looks like the best spot will be having the compressor end mounted up high into the hood blister.
Today I made an adjustable bracket to check positioning and played around a bit with the clocking of the turbo. It is a really good fit and I initially thought the intake would be an issue, but I have more room than I fist thought I would, except for one thing... the fuel injectors at 1&2 cylinders will be really close to the compressor side of the turbo. I think I'll be able to manage it, but it's going to be damn close even with stubby ls3 injectors..
I managed to pull the ls engine out of the esclade that was occupying my lift over the weekend so it can go outside and the opel can go up on the lift, then I can start finalizing the fitment. All said, I'm pretty sure that this will be where it winds up going...
