1 - 8 of 8 Posts
If the Opel Solex throttle diameter size is approximately 32/ 32 and the Weber is 32/ 36, I would enlarge or trim the heat shield and gaskets to match the Weber 36 mm secondary opening.
Diameter: 32 mm = 1.26 in; 36 mm = 1.42 in. The difference of 4 mm is 0.16 inch.
When the carburetor is installed, check that the throttle bores open completely and gaskets/ heat shield do not interfere.
Check for vacuum leaks:
Run engine at warm idle, then spray carburetor cleaner at all gasket, hose, and hardware junctions to the intake manifold. If the idle speed suddenly changes at a location, you have a vacuum leak.
Could you repeat that, and explain better? What does that sudden change means? That the carburetor spray, being flamable, is sucked in and burned?
Thanks a lot
Thanks a lot
The carb cleaner will seal, momentarily, where there is a vacuum leak, however small the leak may be, the "change" you will notice is when the rough running motor smooths out temporarily when the carb spray finds the vacuum leak.
I've also used a propane torch with the head cutoff and a short piece of hose to locate leaks.
If your lucky enough to have a O2 sensor installed it'll tattle tail small leaks.
Then there's the smoke machine ..here.. a much safer way to find vacuum leaks. It runs on, of all things, Baby Oil!
1 - 8 of 8 Posts
