1 - 2 of 2 Posts
Hey, I'm about to purchase new wheels and tires for my 73 GT. I'm wanting to reduce the gap between the fender and top of the tire typically on stock GT's w/ 13" wheels. This gap seems to be around 4" and has always seemed too much to me.
My goal is to lower the car 1 1/2" while also slightly increasing the total circumference of the wheel/tire setup to fill the gap w/o getting crazy low or causing rubbing. I've put a sport spring on the front and cut the rear springs to lower it 1 1/2".
My question is, will this wheel/tire set up work on a GT that's lowered 1 1/2" w/o major modifications?
205/50 R16's x 8" wheels / +20mm offset
Diameter: 24.1"
Width: 8.1"
Sidewall: 4"
Circumference: 75.6"
Original Set up: 165/80 R13's
Diameter: 23.4"
Width: 6.5"
Sidewall: 5.2"
Circumference: 73.5"
I've read tons of info here and from OGTS about wheel/tire setups but I can't seem to find out if this will work or not. My main concern is increasing the circumference by 2", I hoping to increase it some to close the gap as I mentioned but I'm worried this maybe too large and cause issues.
Any help would be greatly appreciated.
I'm running 205/45-16 on a 7.5" rim on the front and 245/45-16 on a 9" rim on the rear.
1 - 2 of 2 Posts
