Hello all. My name is Kevin. I have a shop in Northern California, Red Bluff to be exact. I am currently fist deep in a project for a customer and just foumd this forum. Love it, full of great info!
The project car is a 1970 Opel Kadett. It came in with a partially disassembled engine. It had apparently lost oil pressure and imploded some 10 or more years ago. More recently the head was removed for inspection of cylinders/pistons, and left in a disassembled state until in my care.
We have already installed the upgraded suspension, 1 1/2" lowering leaf and rear coils, all Poly bushings, heavy rear sway bar, and powder coated all suspension components.
The motor is a one off custom. 1.9 liter bored to 2.0. 1.9L head mild port work. Pistons are Venolia, forged aluminum, built to our specs to achieve a 7.8:1 compression ratio.
Intake is a 83ish vintage, euro Opel/GM EFI manifold with Bosch injectors. A FAST Fuel XFI 2.0 EFI computer and harness(LS1) are being adapted to control fuel and ignition. (Currently in talks with Pertronics to have a custom built distributor made to work with the XFI system) Also required is an upgrade to an LS1 throttle position sensor(same GM/Bosch style, smaller bolt pattern). The original TPS is an idle, open, full throttle type, the XFI requires a reostatic type.
To plumb exhaust to turbo I built a one off header and crossover tube. This allowed me to locate the Garrett turbo on the drivers side of motor in the dead space in front of the master cylinder. Also upgrade to 90 amp Bosch alternator...generator and EFI... No buenos! Routing of down tube is tight but wrapped around and under the mastcylinder.
Well not sure if these pics will post but here we go...
