Hi and excuse the brain fog. Is this the proper position for an original retractor n a 1973 Opel or do I have ii inverted? It sucks to get old. Thanks!
Since you never got an answer....
Yes, retractor somewhere near the bottom of the B pillar, if you have the bolt hole for it, with the "coathanger" at the top. If you don't have the lower bolt hole you can fabricate a metal plate to bolt to the area below the side rear windows.
Is this the proper position for an original retractor in a 1973 Opel or do I have ii inverted? It sucks to get old. Thanks!
It is inverted. The belt comes out the bottom and the metal bracket the belt passes through bolts to the rocker panel beside the seat.
Harold
