I pulled the distributor out that had the Pertronics and dropped in the Crane one that is set to about 7 degrees that equates to 14 or 15 degrees of mechanical advance. I set initial at 16 and it seems to like it just fine. I checked it and total now is around 32 or 33 and it is all in at about 3500 RPM. I'm not sure why but I was glad I checked it, the carbs were way out of sinc. set them back and it pulls evenly again and it doesn't rock the body at idle. Temp is normal and it seems to pulse a little harder from the exhaust than it did before. Did I mention that the sewing machine sound from the head is gone? Thanks to Samdog I like the rollers and the improved way it sounds just for starters. I did cut a stock valve cover and am planning on putting windows in it just for fun.
It's also running 2 bar at 1000 for oil pressure.
