1 - 9 of 9 Posts
here are a couple of pictures of the swap...
the first is the interior, that is the m coupe steering wheel, column, pedal cluster, and dash. the turbo wiring harness is everwhere, thats a t-5 tranny with b&m shifter, and a vette seat.
i am going to try to take it for a trip around the block by next weekend...jon
this is of the tubular lower a arm that i just finished. i used the tbird lower balljoint to fit the tbird spindle. i havn't got the upper done yet, but it has an adjustable rod end to give me camber adjustments
this is of the ford 8.8 posi rear end, i just finished welding on all of the opel suspension mounts. after narrowing it 3.5" on each side and resplining the axles. now i have to figure out how to 'make' a torque arm for it??? ideas?
crazy opeler
Wow that has to be one of the coolest swaps that I have seen yet, how much did that dash and seats cost you?
TOO COOL! How did you do overall for GRM?
jon, I take it you figured out the axle? I was gonna reply "why use a t-tube". I thought w/ that nice setup, just go for a std. axle arrangement.
1 - 9 of 9 Posts
