weird wires, broken cable
I'm going through a spare heater box assembly because the one in my GT makes a horrid racket when it first comes on. I have to tear in there anyway as the heater lever/cable/valve is not operational and I want to fix it.
so I took apart the spare box to get at the motor to make sure it works, two wires coming out of motor, one black one red. One post here says it is grounded through the box casing with a brown wire and then a black and a black/red/white wire. Not the case for my spare (not sure about what's in the car now, 1970).
I put the red on the + terminal of a battery, the black on - and the motor took off (just for a split second).
I suspect my current (in the car) motor just has some crap in the box and I can clean it out.
Now the question: both my boxes have the cable to the heater valve broken. Both controls seem okay, just busted cables. Can one just get the cable off the shelf and replace? (the thin "wire" portion and run it through the existing sheating) Looks like a pain the way those cables are attached on the control arms, probably better to splice in.
Any one done this?
