1 - 20 of 355 Posts
Administrator
After slowly working on it for the past two years, things are moving forward with this transplant.
More updates to follow.
Detroit,where my home was
3.0 DOHC nnnnnniiiiiiicccccceeeeeeeee :yup:
Administrator
Discussion Starter #5
What is your plan for driveshaft? I see the output shaft takes flex disc.
Do you have to modified the engine compartment or firewall to fit the engine.
Looks good.
Pete
I have the driveshaft for that setup. The firewall will need to be cut. How much will be determined by the clearance needed for the aluminum radiator/fan.
Administrator
Discussion Starter #9
I have the R25. Can I use the 1.9L clutch/flywheel/pressure plate/clutch cable/release bearing/ clutch cable and arm?
Pete
The R25 that I have is set up for a hydraulic clutch and the slave cylinder is on the passenger side. (opposite from the 1.9) I don't think it can be easily swapped to the other side.
I think that you can use the flywheel assembly. Just check if the tranny input shaft is the same length as the 1.9.
Administrator
Discussion Starter #13
Good point. The "new" driveshaft will be made once the engine is in place and I get an accurate length. The front section will be shortened and then mated to the Ascona d-shaft.
Pete
1.9 flywheel is 6-bolt attachment. The 3.0 24V uses an 8-bolt crankshaft. Totally different.
Edit: Doh, irrelevent for your transmission question!
Totally agree, I had an Omega Wagon with this engine back in the day and it's a really nice engine.
I miss that car, talk about sleeper, not many wagons with that kind of performance around here at the time and the Omega wasn't exactly known as a performance car
1 - 20 of 355 Posts
