I've been kicking around building an engine up. My thought is to use these pistons
Keith Black/KB Pistons IC835-STD - Keith Black ICON Premium Forged Pistons - Show All - SummitRacing.com
with stock small block rods. the big ends are 2" not 2.045" but milling the crank will solve that. My math points to it being .018" taller than the stock 1.9 and the pistons are just under 95mm so it wont be 2 liters but close.
compression distance stock 1.776"
new pistons are 1.133"
stock rod is 5.039"
small block chevy is 5.7"
1.776" - 1.133" = .643" + 5.039" = 5.682"
so the 5.7" will be .018" taller
only issue I see with this is balancing the flywheel to match rotating assembly
as for the head planned on doing 1.85 intake and 1.5 exhaust basically using RallyBobs suggestions.
Does this sound like a good build or am I setting my self up for a punch in the wallet.
stock rod is 5.039"
