Hello,
I have a new getrag 5-speed and it seems like the speedometer cable may be a tight fit. Are there tricks to this upgrade? I don't want it to get bound up from too tight of connection.
Thanks,
Dave, do you have the 90 degree adapter for the speedo cable at the tranny? That will usually give you a couple of inches longer cable and also straighten it out towards the front of the car instead of curving out and then forward from the tranny. HTH.
Ron
· Member
I ran into this same problem a few years back. I went to a local speedo shop and the guy made me a new cable 6" longer.
It cost me $12!
Jc
New cable, no speed
I got a longer cable ($38 vs. much more for a 90 degree adapter) from OGTS and attached it to speedo and trany. I tightened it down as far as I could, but could not get it to move the odometer or speedometer.
I am planning to remove the speedo side and see if it spins when the car is driving, however this seems kinda silly with one person in the dark.
I searched the forum for ideas and now I am checking here to see if someone knows if I should have do some special to align the cable or other ideas.
Thanks,
· Banned
I have the 5 speed and use a stock cable. I would look at the routing of the cable to see if there is a shorter wat to get there. The one man check of the speedo is easier with a cordless drill and now a flashlight I guess. To check the drive gear I had both wheels off the ground and turned the drive shaft.
