ok, searched forums for an hour, and did not find much about alternatives to five speeds other than the getrag. me being the cheap kid that i am, and not wanting to put big dollars into my GT to go faster and affect its driveablity, i'd rather do a 5 speed swap, to get the feel of more power, better gas mileage, and driveability is not made worse.
so is it correct if i got the implications that the only other options are the s-10 5 speed and the chevette/pontiac t-1000 trans? and to use these transmissions, you need a opel automatic driveshaft (most chevy splines are the same as automatic opel)? speedo cable must be used from the new transmission also, and the shifter is 6 inches too far back, and the shifter location cannot be changed.....am i correct on all of this, or is there another way that has not been discussed, or is there a way to move the shifter atleast? i know the s-10 cannot be moved, as its what i believe is called a toploader trans.
