The point gap of .018 is good, plugs gapped at .030. To check for voltage at the coil, if you have a VOM, is simple, turn key on, check for voltage at the + side of the coil where the transparent wire goes to the coil, it should read 6-9 volts. While the engine is cranking check the same terminal on the coil, it should read 9-12 volts. The thing here is two different sources for power to the coil, one during starting, the other in the run position. Gotta have both, one for the engine to start, the other to keep it running. No VOM, no problem, pull a plug, connect it to the plug wire and lay the plug on the engine so it is grounded, crank the motor and there should be a nice fat blue spark between the center of the plug and the ground tang. Of course another way to see if the coil is getting power is to check the tach during starting, if the needle moves it means there is a ground through the coil to the points. HTH.
